Next revision | Previous revision | ||
ms_sensing_during_specific_times [2010/09/28 19:21] jay created |
ms_sensing_during_specific_times [2019/01/26 00:10] (current) |
Line 1: | Line 1: | ||
+ | ====== Motion sensing only during a specific time ====== | ||
+ | So, you have this cool motion sensing light. But, what if you only want the light motion sensing to work between 10pm and dawn? The easiest way is to make a couple of Time Date Trigger actions that will enable/disable the **//Front Porch Motion Detected//** that were created in the [[ms_porch_light|Motion Triggered Porch Light]] scenario. **NOTE**: this technique only works with the [[ms_porch_light|Motion Triggered Porch Light]] scenario - if you have directly linked your Motion Sensor to your switch via INSTEON links it will always work because Indigo won't be involved with the action. If you have **Indigo** triggering off of various device events, then you probably have something similar. | ||
+ | === Defining the Enable Front Porch Motion Trigger === | ||
+ | - Select ''**Time/Date Action List**'' from the ''**View**'' menu | ||
+ | - Press the ''**New...**'' button at the top of the main window | ||
+ | - Name the trigger ''**Enable Front Porch Motion Trigger**'' | ||
+ | - Enter ''**10:00 PM**'' from the first time selector in the ''**Time**'' section | ||
+ | - Choose the ''**Actions**'' tab | ||
+ | - Select ''**Enable Trigger Action**'' from the action ''**Type**'' popup | ||
+ | - Select ''** Front Porch Motion Detected**'' from the ''**Enable:**'' popup | ||
+ | === Defining the Disable Front Porch Motion Trigger === | ||
+ | - Name the trigger ''**Disable Front Porch Motion Trigger**'' | ||
+ | - Select ''**Sunrise**'' in the ''**Time**'' section | ||
+ | - Select ''**Disable Trigger Action**'' from the action ''**Type**'' popup | ||
+ | - Select ''** Front Porch Motion Detected**'' from the ''**Disable:**'' popup | ||
+ | That's it! Now, the motion sensing will only happen between 10pm and sunrise. | ||
+ | In Indigo 5 and greater, we significantly enhanced the condition editor and added a bunch of new conditions. One new condition is the ability to specify time ranges. So, rather than making two triggers as above, simply define the triggers as specified in the [[ms_porch_light|Motion Triggered Porch Light]] scenario - except on the Conditions tab specify "If time" "is between" "10:00pm" and "6:00am" (not exactly dawn, but close). This makes the solution much simpler. |
