Motion sensing only during a specific time
So, you have this cool motion sensing light. But, what if you only want the light motion sensing to work between 10pm and dawn? The easiest way is to make a couple Time Date Trigger actions that will enable/disable the Front Porch Motion Detected that were created in the Motion Triggered Porch Light scenario. NOTE: this technique only works with the Motion Triggered Porch Light scenario - if you have directly linked your Motion Sensor to your switch via Insteon links it will always work because Indigo won't be involved with the action. If you have Indigo triggering off of various device events, then you probably have something similar.
Defining the Enable Front Porch Motion Trigger
- Select
Time/Date Action Listfrom theViewmenu - Press the
New…button at the top of the main window - Name the trigger
Enable Front Porch Motion Trigger - Enter
10:00 PMfrom the first time selector in theTimesection - Choose the
Actionstab - Select
Enable Trigger Actionfrom the actionTypepopup - Select
Front Porch Motion Detectedfrom theEnable:popup
Defining the Disable Front Porch Motion Trigger
- Press the
Disable Front Porch Motion Trigger - Select
Sunrisein theTimesection - Choose the
Actionstab - Select
Disable Trigger Actionfrom the actionTypepopup - Select
Front Porch Motion Detectedfrom theDisable:popup
That's it! Now, the motion sensing will only happen between 10pm and sunrise.
In Indigo 5 and greater, we significantly enhanced the condition editor and added a bunch of new conditions. One new condition is the ability to specify time ranges. So, rather than making two triggers as above, simply define the triggers as specified in the Motion Triggered Porch Light scenario - except on the Conditions tab specify “If time” “is between” “10:00pm” and “6:00am” (not exactly dawn, but close). This makes the solution much simpler.
