iCal Alarm Processor
You can also have iCal send an email alert, and that's where this plugin gets it's power. iCal alarm emails have information about the event in the email message - when it's taking place, it's name, and even any information typed into the “note” field of the event in iCal. This plugin will monitor an IMAP email address, watching for these specially-formatted emails. When it finds one, it can do various things for you, which we will cover below.
| Execute a Group | Group::1282734394 |
| Execute a Trigger skipping Conditions | Trigger::982343093::False |
| Execute a Schedule evaluating Conditions | Schedule::982343093::True |
Each directive should be on its own line. The first word is what kind of object should be executed (Trigger, Schedule, Action Group). Then a double colon “::” separates the ID of the object. Finally, for Triggers and Schedules, another double colon followed by “True” to evaluate conditions or “False” to ignore conditions.
That's pretty much the function of this plugin. If you want to force the plugin to check for alerts between its normal polling period, you can select “Check for Alarms” on the iCal Alarm Processor menu and it will immediately check and process any email.
Scripting Support
Support and Troubleshooting
The plugin is expecting the date in this format: “September 09, 2014 08:45 PM” or without the time (“September 09, 2014”) in the case of an all-day event. This is the standard format for North American macOS systems. You can set date/time formats for any system in the Language & Region settings. I believe iCal uses the “Long” format for the date and “Short” for the time though I'm not positive. Because we don't (can't probably) get locale settings in Python it would be difficult to take into account all possible date/time formats unfortunately.
For usage or other troubleshooting tips discuss this plugin on our forum.
