NOAA Weather
NOAA stations are primarily Airports in the US, and those tend to have the most data. There are other NOAA stations as well but the data from them tends to be spotty at best. Why do we use NOAA data, which is only available in the US, rather than some other provider (like WeatherUnderground or WeatherBug)? Put simply, they either have severe restrictions on what commercial users can do with the data or they require licensing fees. Neither of which we're currently prepared to deal with. NOAA data is completely free and unencumbered. You may have heard that Google has a weather API - which is technically true. It's not a published API and we're not big fans of using unpublished APIs (they tend to break with no warning).
NOAA Trigger States Image
  • Latitude - Latitude
  • Longitude - Longitude
  • Observation Date/Time - The last time the data was updated by NOAA. This field is in RFC822 Date/Time format (i.e. “Fri, 19 Aug 2011 11:51:00 -0500”) so it can be parsed by other software if needed.
  • Quality Codes - For scripters to account for the relative quality of the various weather observations (JSON). This state is only available in Indigo 2022.1 and later.
  • Time Zone - The timezone as it applies to the observed location. This state is only available in Indigo 2022.1 and later.
  • /www/perceptive/wiki/data/pages/plugins/noaaweather.txt
