The Indigo Reflector Service
Note: this wiki page is about the Indigo Reflector service for Indigo 6 (left here for legacy purposes). Check here for the reflector docs for the latest Indigo version.
About Indigo Reflectors
Indigo Reflectors is a service that gives you secure (HTTPS) remote access from anywhere to your Indigo Server with no network configuration needed. This is particularly useful for those of us that have dynamic (vs. static) IP addresses at home, or that have routers or networks that are difficult to configure for remote access to your Mac running Indigo.
Reflectors provide:
- Hassle free setup:
Getting Started
Enabling a reflector is fast and easy. First, make sure you are running Indigo version 6.0.0 or greater(both client and server – check the About Box). Next:
- Choose the
Indigo 6→Start Local Server…menu item. - Turn on the
Require authenticationcheckbox and enter a username and good password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable anywhere secure accesscheckbox. - Press the
Activate Reflectorbutton.
Resetting Your Reflector's Activation
Indigo 6→Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
If the procedure above doesn't work, and if instructed by support, follow these steps to manually reset your Indigo Client reflector settings:
/Library/Application Support/Perceptive Automation/Indigo 6/Preferences/ - In the resulting Finder window, delete the folder named
Bandwidth Limits
