The Indigo Reflector Service
Note: this wiki page is about the Indigo Reflector service for Indigo 6 (left here for legacy purposes). Check here for the reflector docs for the latest Indigo version.
Indigo Reflectors is a service that gives you secure (HTTPS) remote access from anywhere to your Indigo Server with no network configuration needed. This is particularly useful for those of us that have dynamic (vs. static) IP addresses at home, or that have routers or networks that are difficult to configure for remote access to your Mac running Indigo.
Prism Architecture Image
Reflectors provide:
  • Hassle free setup:
Enabling a reflector is fast and easy. First, make sure you are running Indigo version 6.0.0 or greater(both client and server – check the About Box). Next:
  1. Choose the Indigo 6→Start Local Server… menu item.
  2. Turn on the Require authentication checkbox and enter a username and good password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet.
  1. Shut down the Indigo Server (select Indigo 6→Stop Server) but don't quit the Indigo Client
Manual Reset
If the procedure above doesn't work, and if instructed by support, follow these steps to manually reset your Indigo Client reflector settings:
  5. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 6/Preferences/
  • /www/perceptive/wiki/data/pages/reflector/about.txt
