How to simulate sunrise using a dimmable light
We often get asked how to simulate sunrise by gradually increasing the brightness of a lamp over a longish period of time. There are a bunch of different ways of doing this, some specific to the technology, others requiring AppleScript. The first scenario here will be technology-agnostic and not require AppleScript so that both Pro and Lite customers can use this technique.
Any technology, no AppleScript Scenario
This technique has the following components:
- a schedule that, at the appropriate time in the morning, enables the following schedule and sets it to automatically disable after a certain amount of time
- a schedule that repeats every minute, gradually brightening the light
- optionally, a trigger that will cancel the whole shebang by setting disabling the schedule above and turning off the light
So, here's our scenario description: at 5:00am, I want my beside lamp to begin brightening gradually over 20 minutes until it reaches 100%. I also have an X10 remote control that, when I push B1 OFF, it turns the light off and cancels the simulation. OK, with that in mind, let's get started.
First, we'll create the Schedule that actually brightens the light
- Select
Schedulesfrom theViewmenu - Click the
New…button at the top of the Schedule List - Name it
Sunrise Simulation - In the
Time:section, click the radio button besideEveryand change theminutestext field to 1 - Click on the
Actionstab - Select
Device Actions→Light/Appliance Controls→Brighten by %from theAction:popup - Select your lamp from the
Device:popup - Enter
5into theAmount:text field - Click the
OKbutton, and then, in the Schedule list, uncheck the checkbox beside the “Sunrise Simulation” to disable it for the moment
Next, let's create the Schedule that will start the simulation at 5:00am
- Click the
Start Sunrise Simulation - In the
Time:section, change the time in the first box to5:00am - Click on the
Actionstab - Select
Server Actions→Enable/Disable/Reload Actions→Enable Schedulefrom theType:popup - Select
Sunrise Simulationfrom theEnable:popup - Click on the
Auto-disable aftercheckbox and enter0:20:00into the time selector field - Click the
OKbutton
Finally, create the trigger so that when we see a B1 OFF, we stop everything
- Select
Trigger Action Listfrom theViewmenu - Name it
Stop Sunrise Simulation - Select
X10/RF Command Receivedfrom theType:popup - Select
Offfrom theReceived:popup - Click on the
Addressradio in theFrom:section and select B and 1 - Click on the
Actionstab - Select
Server Actions→Enable/Disable/Reload Actions→Disable Schedulefrom theType:popup - Select
Sunrise Simulationfrom theDisable:popup - Click on the
Add Newbutton at the lower left side of the window to add another action - Select
Device Actions→Light/Appliance Controls→Turn Offfrom theType:popup - Select your lamp from the
Device:popup - Click the
OKbutton
That's it! Now, every morning at 5:00am, you'll get a simulated sunrise over 20 minutes, and if you hit the B1 OFF button on your X10 remote, it will stop it and turn the light back off. Obviously, there are several things you can adjust about this: the amount of time that it takes, the ramp rate, use a different remote, etc. But you get the general idea.
