X10 Security Events
Event Types
Commands are normally manually created by human intervention on a Remote Control, whereas Detection occurs when a device is triggered by the event that it was designed to detect.
- sec_ArmHome_min - Command: Arm home with minimum delay to action the arming
- sec_ArmHome_max - Command: Arm home with maximum delay to action the arming
- sec_ArmAway_min - Command: Arm home with minimum delay to action the arming
- sec_ArmAway_max - Command: Arm home with maximum delay to action the arming
- sec_Disarm - Command: Arm home with maximum delay to action the arming
- sec_Panic - Command/Detection: Triggered by either a Panic Button on a Remote Control (ie SH624 or KR21E) or a Smoke Detector (SD90E) detecting smoke or being tested
- sec_LightsOn - Command:
- sec_LightsOff - Command:
- sec_SensorNormal_min - Detection: Sensor reset with minimum delay prior to enactment, Door or Window Closed or Motion No Longer Detected
- sec_SensorNormal_max - Detection: Sensor reset with maximum delay prior to enactment, Door or Window Closed or Motion No Longer Detected
- sec_SensorAlert_min - Detection: Sensor triggered with minimum delay prior to enactment, Door or Window Opened or Motion Detected
- sec_SensorAlert_max - Detection: Sensor triggered with maximum delay prior to enactment, Door or Window Opened or Motion Detected
Thus, to evaluate what response is appropriate it is necessary to evaluate both the event and the device type.
