Z-Wave® Terminology and Technical Overview
Z-Wave is a wireless (RF) home automation technology that's available worldwide. There are several characteristics of Z-Wave technology that we think are important for users to understand. In this wiki article, we'll attempt to explain these features in terms that our users will find easily understood.
This page is about the Z-Wave technology in general terms: if you're ready to get started using Z-Wave with Indigo, check out the Managing Your Z-Wave Network document.
Z-Wave is a wireless mesh network technology. That is, all signals are transmitted over RF (for those with power line-based systems, no more signal noise problems from stuff plugged into the wall). Z-Wave is a proprietary technology, owned by Sigma Designs, and licensed to a variety of vendors. The Z-Wave Alliance was formed by various vendors to help assure interoperability between devices.
If you are an existing Indigo user, specifically one who uses INSTEON, you may recognize the term “controller” to mean a device which can control other devices: KeypadLinc, RemoteLinc, SwitchLincs, etc. You can link a controller directly to a “responder” such that when a button is pressed on a keypad or switch, a command is sent directly from it to the linked “responder” device. Z-Wave has a similar mechanisms (Associations and Scenes) which we'll discuss in a bit.
However, Z-Wave uses the word “controller” differently.
The Z-Wave primary controller is responsible for assigning network id and node ids to devices (Z-Wave devices are referred to as a “node”) and to create Secondary Controllers. This controller is the one that keeps the definitive list of nodes on the network. There must always be a primary controller in any Z-Wave network. For Indigo controlled Z-Wave networks, the primary controller will be the Z-Stick - it will create the network id (or home id) and will assign node id's to any device that's added to the network (see Building a Z-Wave Network below for more details on how to add devices to the network).
A Z-Wave network can also have optional secondary controllers. These controllers will be added by the primary controller and will maintain a copy of the network. This allows the controller to also add devices to the network. The only limitation of a secondary controller is that it can't include other secondary controllers - only the primary can do that.
Including/Excluding a device in a Z-Wave Network
When you add a device to a network via the controller, it's called “including” the device (i.e. the inclusion process). Each device may have a different inclusion process. Likewise, you must exclude a device from the network if you are no longer using it
You can usually include and exclude devices directly from Indigo. Older versions require you to take your interface to the device to include/exclude it using the button on the interface (i.e., Indigo 6).
Z-Wave uses a routed mesh network for extending the range between all modules. For reliable communication to occur between distant modules, an established route, or path, needs to be created. Indigo tells the Z-Stick to create these routes when a module is Define or Synced. If you move modules to different locations it may be necessary to re-Sync them so that their new routes can be established. If you are unable to communicate with a distant module, then try re-Syncing modules that are nearby the distant module to help establish a new route.
Further Reading
  • /www/perceptive/wiki/data/attic/z-wave.1719446928.txt.gz
