Z-Wave® Terminology and Technical Overview
Z-Wave is a wireless (RF) home automation technology that's available worldwide. There are several characteristics of Z-Wave technology that we think are important for users to understand. In this wiki article, we'll attempt to explain these features in terms that our users will find easily understood.
This page is about the Z-Wave technology in general terms: if you're ready to get started using Z-Wave with Indigo, check out the Managing Your Z-Wave Network document.
Overview
Z-Wave is a wireless mesh network technology. That is, all signals are transmitted over RF (for those with power line-based systems, no more signal noise problems from stuff plugged into the wall). Z-Wave is a proprietary technology, owned by Sigma Designs, and licensed to a variety of vendors. The Z-Wave Alliance was formed by various vendors to help assure interoperability between devices.
Controllers
If you are an existing Indigo user, specifically one who uses INSTEON, you may recognize the term “controller” to mean a device which can control other devices: KeypadLinc, RemoteLinc, SwitchLincs, etc. You can link a controller directly to a “responder” such that when a button is pressed on a keypad or switch, a command is sent directly from it to the linked “responder” device. Z-Wave has a similar mechanisms (Associations and Scenes) which we'll discuss in a bit.
However, Z-Wave uses the word “controller” differently.
Primary Controller
The Z-Wave primary controller is responsible for assigning network id and node ids to devices (Z-Wave devices are referred to as a “node”) and to create Secondary Controllers. This controller is the one that keeps the definitive list of nodes on the network. There must always be a primary controller in any Z-Wave network. For Indigo controlled Z-Wave networks, the primary controller will be the Z-Stick - it will create the network id (or home id) and will assign node id's to any device that's added to the network (see Building a Z-Wave Network below for more details on how to add devices to the network).
Controller Types
Including/Excluding a device in a Z-Wave Network
When you add a device to a network via the controller, it's called “including” the device (i.e. the inclusion process). Each device may have a different inclusion process. Likewise, you must exclude a device from the network if you are no longer using it
You can usually include and exclude devices directly from Indigo. Older versions require you to take your controller to the device to include/exclude it using the button on the controller (i.e., Indigo 6).
Associations
Routing and Network Healing
Z-Wave uses a routed mesh network for extending the range between all modules. For reliable communication to occur between distant modules, an established route, or path, needs to be created. Indigo tells the Z-Stick to create these routes when a module is Define or Synced. If you move modules to different locations it may be necessary to re-Sync them so that their new routes can be established. If you are unable to communicate with a distant module, then try re-Syncing modules that are nearby the distant module to help establish a new route.
Glossary of Terms
| Term | Definition |
| Association | A pre-defined grouping of Z-Wave devices that allows them to interact with each other. |
| Command Class | A standard set of instructions that defines how a Z-Wave device can communicate and perform specific actions. |
| Controller | A hardware device that acts as the primary hub and manages the Z-Wave network, including routing and security. |
| Encryption | Devices that support encryption use a secure transmission protocol to relay traffic. Not all devices support encryption, and it is recommended that encryption should only be used in circumstances where security is important like door locks. |
| Exclusion | Exclusion mode is a controller state that allows devices to be removed from a Z-Wave network. |
| Hop Limit | In a Z-Wave network, the hop limit is four hops. This means that a signal can travel through a maximum of four intermediate Z-Wave devices (routers) to reach its destination. The maximum range with four hops is roughly 600 feet (or 200 meters). |
| Hub | A hardware device that typically contains both communication circuits and a software application to manage a Z-Wave network. Indigo, along with a Z-Wave hardware controller, acts the hub in a Z-Wave network. |
| Inclusion | Inclusion mode is a controller state that allows devices to be added to a Z-Wave network. |
| Interface | The software component used to communicate between Indigo and the Z-Wave Network. |
| Mesh Network | A network where devices communicate with each other directly or through intermediate nodes, allowing for a wider range and better signal reliability. |
| Node | A single device in a Z-Wave network. |
| NodeID | A unique identifier for each Z-Wave node within the network. |
| Optimization | Indigo supports a feature to optimize the Z-Wave network by iterating through all network devices to “refresh” their settings and routing tables. This is typically only required when significant changes are made to a network (for example, many devices are added/moved/removed from the network). |
| Parameter | Z-Wave devices typically have parameters that dictate how the device behaves. For example, a dimmer may have a setting to control how quickly a light's intensity will change, or determine how frequently a battery-powered device sends data. |
| Primary Controller | The main controller that manages the Z-Wave network. |
| Repeater | A Z-Wave device that's purpose is simply to pass traffic along the network. Repeaters help extend the range of the network. |
| Secondary Controller | A secondary controller can control Z-Wave devices, but it cannot add new devices to the network (only the primary controller can include or exclude devices). Secondary controllers are added or removed from the network by the primary controller. An example of a secondary controller would be a hand-held Z-Wave remote. |
| Raw Command | Raw commands are how Indigo communicates with the Z-Wave network. Indigo supports sending custom raw commands via the Z-Wave interface. This is more of an advanced feature. |
| Sensor | A device that detects and transmits information to the network, such as temperature or motion. |
| Z-Wave | A wireless communications protocol that uses low-energy radio waves to connect smart devices in a mesh network. |
Further Reading
