The Indigo 2022.1 application can be found here:
By default, database files are stored in the Databases
folder in that folder.
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2022.1 installer again (which will repair any permission issues that Time Machine may have introduced).
The installer moves customer-installed images and other files from either of these folders:
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Web Assets/ /Library/Application Support/Perceptive Automation/Indigo 2021.2/Web Assets/
Lastly, the shared Python modules folder available during script execution has changed from:
to a Python 3 version:
If you have any existing Python modules/libraries in the old folder you should copy them to the new folder and make sure they are Python 3 compatible.
Indigo 2021.x→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 2021.x→Quit Indigo
menu item./Applications
Indigo plugins can now run under Python 3 and we are working with plugin developers to upgrade Python 2.7 based plugins to 3.10. Indigo 2022.1 will continue to allow older (Python 2.7) plugins to run, but you will see a warning in the Event Log and they will be marked with a yellow status icon in the Plugins menu indicating that they won't be compatible with future versions of Indigo. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
Indigo 2022.1→License Details…
button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)/Library/Application Support/Perceptive Automation/Indigo 2022.1/
(if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2022.1→License Details…
from the Indigo 2022.1
~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-client6.plist
~(your user folder)/Library/Preferences/Indigo 2022.1 Client Prefs.indiPref
~(your user folder)/Library/Preferences/Indigo 2022.1 Client Settings.indiPref
To uninstall older versions but leave 2022.1 installed correctly, delete these:
/Applications/Indigo 2021.2.app
/Applications/Indigo 2021.1.app
/Library/Application Support/Perceptive Automation/Indigo 7.5/
/Applications/Indigo 7.5.app
/Library/Application Support/Perceptive Automation/Indigo 7.4/
/Applications/Indigo 7.4.app
/Applications/Indigo 7.3.app
/Library/Application Support/Perceptive Automation/Indigo 7.2/
/Applications/Indigo 7.2.app
/Applications/Indigo 7.app
/Library/Application Support/Perceptive Automation/Indigo 6/
/Applications/Indigo 6.app
Indigo 2022.1
application (/Applications/Indigo 2022.1.app
).Indigo 2022.1
button in the connection status window.Indigo 2022.1→Start Local Server…
menu item.
Choose the Standard Indigo Startup
Use the Allow remote access
checkbox to enable remote access from other Macs and Web browsers. You must enter a username and password if you enable remote access.
Use the Also allow HTTP Basic authentication (less secure)
checkbox to enable HTTP Basic authentication. This setting allows you to insert the username/password in the URL line. Older services may require this, though we recommend against using it.
Use the Enable secure internet access via Indigo Reflector
Use the Enable OAuth and API Key authentication
checkbox to enable 3rd party services like Alexa. It also will allow REST API calls to use an API key for authentication rather than a username/password. This is more secure since you can revoke a key if it gets compromised without having to change passwords in wherever you may need to use them.
checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server. Note that this only works on your local network - the Indigo Reflector service is only for Indigo Touch and other web access, not for configuration client connections.
Press the Start Server
button, or the Restart Server
button.
Indigo 2022.1
application (inside /Applications/Indigo 2022.1.app
) on the remote Mac.Indigo
on this remote Mac, then press the Connect to Remote Server…
button in the connection status window.Indigo 2022.1→Connect to Remote Server…
menu item.IP address
button.
on the Settings
http://192.168.1.23:8176/
Download Latest Release
button, which will download the plugin. If the release isn't compatible with your version of Indigo, you can click on the Releases tab, and look through the list for a version that works with your version of Indigo (click on it and then click the Download this release
link)..indigoPlugin
. Double-click that file.Open With
menu item, then select Indigo 2022.1.Install and Enable
button.
There is also a yellow version of the green dots - the meaning is the same as the green version except it's indicating that the plugin is using an API version that will be deprecated in an upcoming release. You should check the Plugin Store for an updated version or contact the plugin developer.
The Manage Plugins…
The Plugin Store
will open the Scripts folder (where you can save external scripts in a version-agnostic way).
The Open Scripting Shell
menu. For instance, here's the BetterEmail plugin submenu when it's enabled:
Enable
to enable the plugin and Disable
to disable the plugin.Reload
menu item will reload the plugin and will only be present if the plugin is enabled. Enable debugging menus
item selected in the Plugins tab of the Indigo Preferences (and are discussed in that section).The next section contains:
Configure…
menu item will open a config dialog if the plugin has plugin-specific configuration items (if not or if the plugin is disabled, it will not be present). Show in Plugin Store…
menu item will open the plugin's entry in the Plugin Store in the default browser. If there is an available plugin update that will work on your version of Indigo, the menu title will be Download New Version…
which will also open the plugin's entry in the Plugin Store in the default browser so you can download the new version, and if there is an incompatible version the menu title will be Incompatible Version Available…
which will drop a sheet showing what version of Indigo is required to run the new plugin version. This menu item will always show, but if it's grayed out it means the plugin isn't from the Plugin Store.Copy Plugin ID
menu item will always show, and when selected will copy the plugin's unique ID for use in scripts.About…
menu item will always show the current version of the plugin and will always be enabled.Any sections below this are specific to the plugin and will contain commands that the plugin presents to the user. If the plugin is disabled, no additional sections will be displayed.
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2022.1→Preferences…
menu item discussed above.
checkbox will add two new menus to the plugin's menus: Reload in Debugger
will reload the plugin and connect to the selected debugger; Reload in Interactive Shell
will open a terminal window with a Python shell that's connected to the plugin so the developer can run commands and inspect arbitrary objects in the running plugin.Use debugger
popup is used to tell Indigo which debugger to start the plugin up when you use the above menu items. See the Python Debugger Support forum post for further details on how to use these features to aid in developing a plugin.
Help→Show Indigo Server Install Folder
menu item. This will switch you to the Finder and open a window to the Indigo install folder.Indigo 2022.1→Stop Server
menu item in the Mac client (you can leave the client app running).Plugins
and Plugins (Disabled)
. Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin.Start Local Server…
button in the Server Connection Status
dialog.The plugin will no longer show in the Plugins tab or in the Plugins menu.
System Preferences
from the Apple
menu.Date & Time
icon.Time Zone
panel.Closet City
checkbox.Latitude
and Longitude
coordinates.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2022.1→Preferences…
tab.
You can have Indigo check for updates immediately by selecting the Indigo 2022.1→Check for Updates…
menu item.
System Preferences
from the Apple
menu.Energy Saver
icon.Computer sleep:
slider to Never
checkbox.Congratulations! You should now have a basic functioning Indigo installation that's ready for you to start adding devices and defining your home automation logic. We suggest that you next go to the Overview of Devices, Triggers, Schedules, Action Groups, Control Pages, and Variables - that will give you the information you need to begin using the features of Indigo.
