Note: this plugin was added in the Indigo 2021.2 installer. If you were using the Better Email plugin from the Plugin Store before you upgraded, the upgrade process should have worked seamlessly and you shouldn't need to do much. The one thing you may need to change are any scripts that send emails using the Better Email plugin: you will need to change the id to com.indigo.email
(see the Scripting Emails section below for details). The same applies to other plugins that were subscribing to broadcast messages.
If you had a previous version of Indigo configured to send emails, the upgrade process will create this server for you based on your prior settings. The name of that server will be Email+ SMTP Server
In Indigo, create a new device, in the Type
popup select Email+ and for Model
select SMTP Server
In the Actions tab, you can use the Notification Actions→Send Email
action to send an email:
The format can be either plain text or HTML (it is your responsibility to ensure that the Message field contains a valid HTML document - we don't attempt to validate it). Variable (%%v:VariableIDHere%%
) and device state (%%d:DeviceIDHere:StateIDHere%%
) substitutions are available in all fields, and you can specify attachments by entering the full path to a file, each file separated by commas.
In the Actions tab, you can use the Notification Actions→Send Indigo Log Email
action to send parts of your Event Log lines:
) substitutions are available in all fields.
In addition to the Notification Actions
mentioned above, there are four more Email+ actions to choose from.
1. You can use the Email+ Actions→Poll All Email Servers
item to poll all configured SMTP servers to query for new messages.
2. You can use the Email+ Actions→Poll Email Server
item to poll a specific SMTP server for new messages.
3. You can use the Email+ Actions→Clear All Email Queues
item to clear out all queued emails from all of your SMTP servers. If your email server is having issues, you may find that you want to clear out all pending emails that the plugin has queued up for your email server.
4. You can use the Email+ Actions→Clear Email Queue
item to clear out the email queue for a specific SMTP server.
select IMAP Server
When configuring your IMAP device, you will need to confirm the settings with your email provider. The defaults for Encryption and Server Port are usually correct, though that is provider specific. Most email providers Use IDLE
, but if things don't seem to be working you can check with your provider for this setting.
There are 3 options for the After Message is processed field
Leave in INBOX
(default) - this is the safest option if you are using this email address for other things. It can lead to an ever growing email list, so you'll need to delete messages yourself once you're sure you are done with them.Delete Message
- if you are using a dedicated email address for Indigo, this is a good option since it will delete a message after it's been processed. This will keep the inbox from growing uncontrollably.Move Message
- this is a compromise of the two options above: it keeps the INBOX clean but it also keeps all emails if you want to manually manage them.
The Check All
button is really used for testing - it will process all emails regardless of whether they have been processed in the past or not.
If you had a previous version of Indigo configured with email scanning, the upgrade process will create this server for you based on your prior settings. The name of that server will be Email+ POP Server
select POP Server
String Match in Email
- this event will allow you to perform exact matches in the subject or body of an email, or the sender of the email.RegEx Pattern Match in Email
- this will allow you to use regular expressions to match some subset of text in the above 3 fields.Server Connection Error
- this will fire a trigger when there is some kind of error in any of the 3 server types above.Other plugin developers can subscribe to messages from the Email+ plugin when emails are sent or received:
MessageType: messageReceived Returns dictionary: { 'messageFrom': <text string>, 'messageTo': <text string>, 'messageSubject': <text string>, 'messageText': <text string> } MessageType: messageSent Returns dictionary: { 'messageFrom': <text string>, 'messageTo': <text string>, 'messageSubject': <text string>, 'messageText': <text string> }
def sendAlertEmail(subject, message): plugin = indigo.server.getPlugin("com.indigodomo.email") if plugin.isEnabled(): plugin.executeAction("sendEmail", deviceId=12345678, props={'emailTo':'foo@bar.com', 'emailSubject': subject, 'emailMessage': message}) return sendAlertEmail("Test Alert", "This is only a test")
props = { 'emailTo': 'address1, address2', 'emailCC': 'address3, address4', 'emailBCC': 'address5, address6', 'emailSubject': 'Message Subject', 'emailAttachments': 'file1, file2, file3', 'emailFormat': 'plain' (or 'html') 'emailMessage': 'Message text' } plugin = indigo.server.getPlugin("com.indigodomo.email") if plugin.isEnabled(): plugin.executeAction("sendEmail", deviceId=12345678, props=props)
