This page describes how Indigo 2022.1.0 works with Python, specifically with respect to packages/libraries.
Indigo 2022.1 shipped with API version 3.0 and is the first version to contain support for Python version 3 (check the API Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 2 and Python 3 are now automatically installed as part of the Indigo installer. For Indigo 2022.1, we are including both Python 3.10.2 and Python 2.7.18 (for backwards compatibility - it is an x86 install and will require Rosetta to run on Apple Silicon Macs). The Python 2.7.18 install was specifically added because macOS 12.3 removed its Python install and is a transitional step only. Python 2 and support for APIs < 3.0 will be removed in Indigo 2022.2 later this year.
The Indigo 2022.1 installer includes the Python 2.7.18 installer (which is Intel only) and the Python 3.10.2 installer (includes Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can to try and avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums.
As noted above, Indigo 2022.1 ships with two versions of Python. Each version contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports. As a reminder, the support for Python 2 will be dropped in Indigo 2022.2.
For plugins that use Python 3, use pip3 install [package]
commands to install packages:
For plugins that use Python 2, use pip2 install [package]
Last login: Tue jan 1 12:34:56 on console user@my mac ~ % pip2 install pytorch ...
To see which packages are installed, use the list
command:
Note: Some Python packages – and specifically those that are included in IPH3 as described below – will not appear in the pip3 list
output.
To see more detailed information about an individual package, use the show
command.
Last login: Sun Mar 27 10:20:04 on ttys000 user@my mac ~ % pip3 show requests Name: requests Version: 2.27.1 Summary: Python HTTP for Humans. Home-page: https://requests.readthedocs.io Author: Kenneth Reitz Author-email: me@kennethreitz.org License: Apache 2.0 Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages Requires: charset-normalizer, certifi, idna, urllib3 Required-by: user@my mac ~ %
Particularly helpful in the show
output is the dependencies information – both what the package requires and what requires the package. Note that the dependencies information may not include information about packages that are included with the IPH.
Installing additional Python versions on the Indigo 2022.1 server machine is NOT recommended (see above). Installing additional Python modules should only be done when necessary.
Because the packages included with Indigo should not be modified (to ensure a smoothly running server), plugin developers must include any other desired version within the plugin package. Plugin developers should note that some Python packages will not integrate universally across all installations as they rely on code compiled for specific hardware configurations (for example, Intel vs. Apple silicon). The IPH processes use the following Module Search Paths (Python interpreters use PYTHONPATH
to describe the order of directories to search for installed packages, the first matching package will be used):
The PYTHONPATH
for IPH3 is:
and the PYTHONPATH
for IPH2 is:
Packages are installed in three ways:
Python#-includes
folders above, and those will be shared across all Indigo Plugins and Scripts.pip3
(or pip2
) process. Warning: Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
There are some important implications that result from having some libraries included in the IPH3. Namely, those packages will be available to plugins, Indigo scripts (embedded and linked), the Indigo python shell (from the menu item or by doing indigo-host
in a terminal window), but IPH3 libraries will NOT be available if you start the python interpreter directly (by doing python2 or python3 in a terminal window). Refer to this chart to determine accessibility:
Method | Access to IPH3 Libraries |
plugins | yes |
embedded scripts | yes |
linked scripts | yes |
Indigo python shell using Indigo menu | yes |
If you need a module/package for your plugin, you can install it via pip3
as shown above, which will install it into the Python site-packages
folder. We recommend (but don't require) the following folders be used for custom scripts and modules:
folder. (Indigo versions prior to 2022 should use the /Library/Application Support/Perceptive Automation/Python2-includes
folder).Warning 1: as mentioned above, Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
Warning 2: you should use caution when naming your custom scripts to ensure they don't supplant other Python packages. For example, if you install the holidays Python package using pip3 install holidays
, it will be installed in the site-packages folder. If you also have a custom script in the Python3-includes
folder named holidays.py, the IPH will import your script instead of the site-packages version (because the Python3-includes folder is searched before the site-packages folder).
To provide users with a measure of safety regarding the Python packages that Indigo installs, the Indigo installer also includes the capacity to repair the Python installation if something should become damaged. For example, if a user were to accidentally upgrade one of the Python packages – and as a result cause the Indigo server to stop functioning properly – re-running the Indigo installer may be able to bring things back under control.
Indigo 2022.1 ships with the following Python 3 packages in addition to the packages installed with the standard Python framework.
Included inside IPH 3 Unmodifiable | PIP installed by Indigo PIP Modifiable (but not recommended) |
Python Package | Version | Python Package | Version |
py-applescript | 1.0.3 | cycler | 0.11.0 |
certifi | 021.10.08 | fonttools | 4.31.2 |
charset_normalizer | 2.0.12 | future | 0.18.2 |
python-dateutil | 2.8.2 | kiwisolver | 1.4.0 |
idna | 3.3 | matplotlib | 3.5.1 |
jedi | 0.18.1 | numpy | 1.22.3 |
oauthlib | 3.2.0 | packaging | 21.3 |
packaging | 21.3 | Pillow | 9.0.1 |
parso | 0.8.3 | pyparsing | 3.0.7 |
pudb | 2022.1.0 | python-dateutil | 2.8.2 |
pyaes | 1.3.0 | scipy | 1.8.0 |
pygments | 2.11.2 | six | 1.16.0 |
pyparsing | 3.0.7 | ||
pyserial | 3.5 | ||
requests | 2.27.1 | ||
requests-oauthlib | 1.3.1 | ||
urllib3 | 1.26.8 | ||
urwid | 2.1.2 | ||
xmljson | 0.2.1 |
Indigo 2022.1 ships with the following Python 2 packages in addition to the packages installed with the standard Python framework.
Included inside IPH 2 Unmodifiable | PIP installed by Indigo PIP Modifiable (but not recommended) |
enum | 1.1.6 | backports.functools-lru-cache | 1.6.4 |
oauthlib | 2.0.2 | cycler | 0.10.0 |
requests | 2.10.0 | future | 0.18.2 |
requests-oauthlib | 0.8.0 | kiwisolver | 1.1.0 |
pudb | 2016.1 | matplotlib | 2.2.5 |
py-applescript | 1.0.3 | numpy | 1.16.6 |
pyaes | 1.3.0 | pyparsing | 2.4.7 |
pygments | 2.1.3 | python-dateutil | 2.8.2 |
pyserial | 3.1.1 | pytz | 2022.1 |
python-dateutil | 2.8.2 | scipy | 1.2.3 |
six | 1.16.0 | six | 1.16.0 |
urwid | 1.3.1 | subprocess32 | 3.5.4 |
xmljson | 0.1.7 |
