is generally considered to be Python code and represents the exact code needed. You'll also see code blocks like this:
Term | Meaning |
For Scripters and Developers:
myObject.replaceOnServer()
myObject.refreshFromServer()
method.For Developers:
Devices | ||
Schedule | ||
Schedule (indigo.Schedule) | indigo.schedule.* | manipulate a scheduled event not yet implemented |
Triggers | ||
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger) | indigo.devStateChange.* | manipulate a device state change trigger |
Action Groups | ||
Variables | ||
General Commands | ||
and delete()
and indigo.List()
and list
The behavior of indigo.Dict
and indigo.List
You can convert an indigo.Dict
to a python dict
and an indigo.List
to a python list
, by calling the appropriate methods on those instances. Note, this will recursively convert nested objects (which attempting a manual cast will not):
python_dict = dict(my_indigo_dict) python_list = list(my_indigo_list)
Object | Description |
is a shortcut to get the string name of the item. Normally you would need to get a copy of the object (which would pull the entire object from the IndigoServer) then get the name, but this method is more efficient since it only gets the name from the IndigoServer rather than the whole object. So, an easy way to get a variable folder's name (maybe for logging) would be to do this: indigo.variables.folders.getName(1234)
at plugin start so that you'll always be notified when any device changes - you can then determine if your scene “state” has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change.
Objects that support subscribeTochanges() |
indigo.actionGroups.subscribeToChanges() |
indigo.devices.subscribeToChanges() |
indigo.triggers.subscribeToChanges() |
indigo.variables.subscribeToChanges() |
def deviceUpdated(self, origDev, newDev): # call the base's implementation first just to make sure all the right things happen elsewhere indigo.PluginBase.deviceUpdated(self, origDev, newDev) # do your stuff here - make the network connection if necessary, write the data, etc
Use the lower-level subscribeToIncoming()
and subscribeToOutgoing()
methods in the indigo.insteon
and indigo.x10
command spaces to see commands regardless of their effect on device state. These commands are exclusive to Insteon
and x10
device classes.
Low Level Commands (Insteon and x10 Only) |
indigo.insteon.subscribeToIncoming() |
indigo.insteon.subscribeToOutgoing() |
indigo.x10.subscribeToIncoming() |
indigo.x10.subscribeToOutgoing() |
######################################## def x10CommandReceived(self, cmd): self.logger.debug(f"x10CommandReceived: \n{str(cmd)}") if cmd.cmdType == "sec": # or "x10" for power line commands if cmd.secCodeId == 6: if cmd.secFunc == "sensor alert (max delay)": self.logger.info("SENSOR OPEN") elif cmd.secFunc == "sensor normal (max delay)": self.logger.info("SENSOR CLOSED") def x10CommandSent(self, cmd): self.logger.debug(f"x10CommandSent: \n{str(cmd)}")
for dev in indigo.devices: # do stuff with dev here
Filter | Description |
props.SupportsOnState | return only devices that support an ON state property |
Triggers also have filters:
Possible Exceptions | |
, MemoryError
, OverflowError
# first, let's get an indigo.DimmerDevice like a LampLinc >>> dev = indigo.devices[238621905] >>> dev.__class__ <class 'indigo.DimmerDevice'> >>> hasattr(dev,'onState') True >>> dir(dev) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'brightness', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'onState', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # Next, an indigo.ThermostatDevice >>> thermo = indigo.devices[171495708] >>> thermo.__class__ <class 'indigo.ThermostatDevice'> >>> dir(thermo) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'coolIsOn', 'coolSetpoint', 'description', 'deviceTypeId', 'enabled', 'fanIsOn', 'fanMode', 'folderId', 'globalProps', 'heatIsOn', 'heatSetpoint', 'humidities', 'humiditySensorCount', 'hvacMode', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'temperatureSensorCount', 'temperatures', 'updateStateOnServer', 'version'] # Here's a plugin defined device >>> tunes = indigo.devices["Whole House iTunes"] # notice that it only shows the Device base class >>> tunes.__class__ <class 'indigo.Device'> >>> dir(tunes) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # You can use the deviceTypeId attribute to get the plugin's defined type >>> tunes.deviceTypeId u'mediaserver'
>>> dev = indigo.devices[123] >>> indigo.server.log(f"{dev}") address : batteryLevel : None buttonGroupCount : 0 configured : True description : ... >>> indigo.server.log(f"{type(dev)}") <'indigo.Device'>
>>> dev = indigo.devices[123] >>> dev_dict = dict(dev) >>> indigo.server.log(f"{dev_dict}") {'class': 'indigo.Device', 'address': '', 'batteryLevel': None, 'buttonGroupCount': 0, 'configured': True, 'description': '', ...} >>> indigo.server.log(f"{type(dev_dict)}") <class 'dict'>
Name | Base | Description |
IndigoJSONEncoder | JSONEncoder | Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder) ) |
Command Syntax Examples |
Parameters | |||
This method returns an indigo.Dict
that can be passed directly back to the Indigo Web Server from an HTTP processing call to your plugin. The dict looks something like this:
{ "status": 404, "headers": { "Content-Type": "text/html" }, "file_path": "/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html" }
IWS will use this to create the HTTP reply to stream the file back to the caller. Note that this function will raise an indigo.utils.FileNotFoundError
if the file doesn't exist or a TypeError
if file_path
isn't a list of path parts or a string.
Parameters | |||
Returns True
for an email that is constructed correctly, False
otherwise.
