Note most of the code examples below are calling methods on the object self
. In this context, self
is meant to be the Plugin instance as defined inside the plugin.py
file. To execute the sample code outside of Plugin instance methods, use the indigo.activePlugin
object instead.
Important: For simplicity, some of the samples below specify objects based on name (indigo.devices[“office desk lamp”]
). However, the preferred lookup mechanism is to use the object's numeric ID (indigo.devices[12345678]
), which can be retrieved by control-clicking on the object name in Indigo's Main Window. By using the numeric ID you ensure the object will be found even if its name is changed.
Included in the SDK are examples that create plugin based relay, dimmer, thermostat, sensor, speed control, sprinkler, energy meter and custom devices. Also included is an example showing basic Indigo database traversal, how to catch low-level X10/INSTEON messages, and how to create an Indigo telnet server using the python twisted framework. The following table lists the Indigo Plugin SDK examples that were available at the time Indigo 2023.1 shipped.
SDK Plugin task | Plugin that illustrates an approach |
Broadcast Plugin Information to Listeners | Example Custom Broadcaster |
Subscribe to Plugin Information Broadcast | Example Custom Subscriber |
Walk Through the Indigo Database | Example Database Traverse |
Non-native Device Type | Example Device - Custom |
Energy Meter Device Type | Example Device - Energy Meter |
Device Factory Device Type | Example Device - Factory |
Switch / Relay / Dimmer Device Type | Example Device - Relay and Dimmer |
Sensor Device Type (Water, Motion, Light, Humidity) | Example Device - Sensor |
Speed Control Device Type (Fan) | Example Device - Speed Control |
Sprinkler Device Type | Example Device - Sprinkler |
Thermostat Device Type | Example Device - Thermostat |
Interact with the Indigo Server Using HTTP Client / Server | Example HTTP Responder |
Listen for Insteon and/or X-10 Traffic | Example INSTEON:X10 Listener |
Listen for Indigo Variable Change Notifications | Example Variable Change Subscriber |
Listen for Z-Wave Traffic | Example ZWave Listener |
Parsing JSON, XML from an IP source | NOAA Weather, WeatherSnoop |
Integrating with native Mac Apps | Airfoil |
Sending RS232 (serial port & network serial port) Commands | EasyDAQ |
Reading RS232 (serial & network serial port) Input | EasyDAQ |
Interacting with an IMAP mail server | Email+ |
Interacting with an HTTP Web server | Example HTTP Responder |
Creating custom devices with states | Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ |
Creating custom actions | GhostXML |
Creating custom events | Airfoil |
Each of these plugins is installed by default with Indigo - in the /Library/Application Support/Perceptive Automation/Indigo [VERSION]/Plugins (Disabled)/
folder, or available as an Open Source plugin from the Indigo Plugin Store. To see the various XML and python source files, just right-click on it in the Finder
and select Show Package Contents
PluginConfig.xml
are automatically mapped into the plugin's prefs space which is available via:self.pluginPrefs["somePrefKey"]
someVal = self.pluginPrefs["somePrefKey"] indigo.server.log("value is " + str(someVal))
indigo.server.savePluginPrefs
.pluginProps
.dev = indigo.devices["den fixture"] # device ID preferred newProps = dev.pluginProps newProps["onCycles"] = 5 newProps["moreData1"] = "abc" newProps["moreData2"] = True newProps["moreData3"] = 123.45 dev.replacePluginPropsOnServer(newProps)
dev = indigo.devices["den fixture"] # device ID preferred onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is " + str(onCycles))
dev = indigo.devices["den fixture"] # device ID preferred newProps = dev.pluginProps newProps["onCycles"] += 1 dev.replacePluginPropsOnServer(newProps) dev = indigo.devices["den fixture"] # device ID preferred onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is now " + str(onCycles))
.globalProps
.(useful, but very rough notes below)
<ConfigUI>
XML node. Every field id
is automatically mapped into the device instance .pluginProps
metadata dictionary (described above) as a unique key.<States>
XML node, and are used to define the transient state information for a device (ex: on/off setting, brightness, temperature, etc.).Device State Changed
options when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device.heatSetPoint
by 1:dev = indigo.devices["Custom Plugin Thermostat"] # device ID preferred dev.updateStateOnServer("heatSetPoint", dev.states["heatSetPoint"] + 1)
deviceStartComm
and deviceStopComm
to start/stop any hardware communication (normally via a new per-device thread):def deviceStartComm(self, dev): self.easydaq.startCommThread(dev) def deviceStopComm(self, dev): self.easydaq.stopCommThread(dev)
deviceStartComm
and deviceStopComm
are automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receive deviceStartComm
calls. Likewise, deviceStartComm
is called when a new plugin device is created or duplicated. deviceStopComm
is called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.The XML in this file describes all events that your plugin will generate for use in Indigo. Your users will use these in the Trigger Events dialog just like any of the built-in Indigo events (like Power Failure, Email Received, etc). Your plugin can offer other types of events, including update notifications, battery low notifications, button press notifications, and so on.
file that defines a plugin update event, with a small sample configuration dialog:
<?xml version="1.0"?> <Events> <SupportURL>http://www.yourdomain.com/plugin/pluginEvents.html</SupportURL> <Event id="updateAvailable"> <Name>Plugin Update Available</Name> <ConfigUI> <SupportURL>https://www.yourdomain.com/plugin/someOtherEvent.html</SupportURL> <Field id="someLabel" type="label"> <Label>This label contains some useful configuration instructions.</Label> </Field> </ConfigUI> </Event> </Events>
As you can see, your <Event>
element as well – and separate support elements for the event's configuration dialog (the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL). You can specify an Event to be a separator in your event list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements:
<Event id="sep1"/>
There are several Event-related and Trigger-related methods that you can add to your plugin.py
file–some of which are required in order to have the Event do something. These methods include:
Element | Description |
self.closedEventConfigUi(self, values_dict, user_cancelled, type_id, event_id) | Called after user clicks the Save button within the event configuration dialog (after 'validateEventConfigUi()' method has finished successfully). Used to finalize any Event configuration steps. |
self.getEventConfigUiValues(self, plugin_props, type_id, event_id) | Called when an Event configuration window is first opened. |
self.getEventConfigUiXml(self, type_id, event_id) | Called when an Event configuration window is first opened. The method is used to provide a valid XML payload in place of the Events.xml file. |
validateEventConfigUi(self, values_dict, type_id, event_id) | Called when a user clicks the Save button within the event configuration dialog. Used to provide configuration input validation to ensure the settings are within your parameters. |
The power of Events
Indigo provides a method to do this by allowing the plugin to “subscribe” to changes for all objects in a particular class.
To monitor changes to different classes of Indigo objects, you can include a call to the appropriate subscribeToChanges
method. Calling any of these methods tells Indigo to send a notification to the plugin of any changes to all objects of that type – not only plugin's own objects – so use these methods sparingly.
Element |
indigo.devices.subscribeToChanges() |
indigo.variables.subscribeToChanges() |
indigo.triggers.subscribeToChanges() |
indigo.schedules.subscribeToChanges() |
indigo.actionGroups.subscribeToChanges() |
indigo.controlPages.subscribeToChanges() |
def __init__(self, plugin_id, plugin_display_name, plugin_version, plugin_prefs): super().__init__(plugin_id, plugin_display_name, plugin_version, plugin_prefs) indigo.devices.subscribeToChanges() indigo.variables.subscribeToChanges() indigo.triggers.subscribeToChanges() indigo.actionGroups.subscribeToChanges()
Element |
self.deviceCreated(self, dev) |
self.deviceDeleted(self, dev) |
self.deviceUpdated(self, orig_dev, new_dev) |
def deviceCreated(self, dev): # Receives a copy of the device instance self.logger.debug(f"{dev.name} created."
def deviceDeleted(self, dev): # Receives a copy of the device instance self.logger.info(f"{dev.name} deleted."
def deviceUpdated(self, orig_dev, new_dev): self.logger.debug("===== deviceUpdated =====") # Call the parent implementation of deviceUpdated() base class indigo.PluginBase.deviceUpdated(self, orig_dev, new_dev) # Convert the payload objects from indigo.Dict() objects to Python dict() objects. orig_dict = {} for (k, v) in orig_dev: orig_dict[k] = v new_dict = {} for (k, v) in new_dev: new_dict[k] = v # Create a dictionary that contains only those properties and attributes that have changed. diff = {k: new_dict[k] for k in orig_dict if k in new_dict and orig_dict[k] != new_dict[k]} self.logger.debug(f"Attributes changed: {diff}")
Element |
self.variableCreated(self, var) |
self.variableDeleted(self, var) |
self.variableUpdated(self, orig_var, new_var) |
The variable change monitoring methods operate like the methods for devices above. Note, unlike Indigo devices, you'll need to monkey patch the var
object in order to iterate over it.
