When you double click on the Indigo 2023.1
icon in the Applications
folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
The Home Window has 4 areas:
To create a new folder, select the main object type in the list then click the plus (+
) button at the lower-left corner of the outline view. A new folder will appear and you can just start typing it's new name.
Rename Folder…
allows you to rename the folder.Delete Folder
will do just that. If the folder isn't empty, it will show you a sheet with 3 options: Cancel
(do nothing), Delete Items
(delete the items in the folder along with the folder), or Move Items
(move the items to the parent first then delete the folder).Disable/Enable Remote Display
(for devices, action groups, and control pages) will show/hide it in remote clients (like Indigo Touch for iOS and Web, the DomoPad 3rd party client for Android, etc).Copy ID (123456789)
will copy the unique folder ID for use in Python scripts.To move an object to a folder, just drag it from the list view onto the folder (or top-level object) - somewhat like moving mail messages from the inbox to a mail folder in the Mail application.
The buttons above the table view perform actions on items in the list - the buttons will work on whatever list is displayed in the Item List. So, if you have DEVICES (or a device folder) selected in the Outline View, the item list will show devices and the buttons will operate on that list - New…
device, Edit…
the selected device, Duplicate
the selected device, or Delete
the selected device(s). The search bar will filter the list.
This menu will:
indigo.devices[91776575] # “Living Room Switch”
address : 3B.04.7A batteryLevel : None blueLevel : None brightness : 0 buttonConfiguredCount : 0 buttonGroupCount : 1 configured : True defaultBrightness : 100 description : valve deviceTypeId : displayStateId : brightnessLevel displayStateImageSel : DimmerOff displayStateValRaw : 0 displayStateValUi : 0 enabled : True energyAccumBaseTime : None energyAccumTimeDelta : None energyAccumTotal : None energyCurLevel : None errorState : folderId : 810233868 globalProps : MetaProps : (dict) com.indigodomo.indigoplugin.alexa : (dict) publish-device : true (bool) sub-type : Valve (string) voice-name : valve (string) greenLevel : None id : 1508839119 lastChanged : 2021-09-25 08:24:22 lastSuccessfulComm : 2021-09-25 08:24:22 ledStates : [] model : LampLinc (dual-band) name : Insteon Dimmer onBrightensToDefaultToggle : True onBrightensToLast : False onState : False ownerProps : emptyDict : (dict) pluginId : pluginProps : emptyDict : (dict) protocol : Insteon redLevel : None remoteDisplay : True sharedProps : com.indigodomo.indigoserver : (dict) states : States : (dict) brightnessLevel : 0 (integer) onOffState : off (on/off bool) subModel : Plug-In subType : Plug-In supportsAllLightsOnOff : True supportsAllOff : True supportsColor : False supportsRGB : False supportsRGBandWhiteSimultaneously : False supportsStatusRequest : True supportsTwoWhiteLevels : False supportsTwoWhiteLevelsSimultaneously : False supportsWhite : False supportsWhiteTemperature : False version : 67 whiteLevel : None whiteLevel2 : None whiteTemperature : None
The information in the tile will be specific to the device type. For instance, battery powered devices (that report their battery status) will show the battery level. For sensor devices, the sensor reading will show (temp, humidity, etc. for instance). All devices, regardless of type, will show Last Update
- the last date/time that the device was changed in any way.
Plugin devices, regardless of whether they implement one of the built-in device types below or if they are completely custom devices, will also have a Custom States
tile that will show all of the device's custom states. This tile is always below the first row of tiles so you may need to scroll or resize the Item Detail area to see it:
indigo.devices[1604256801].states["album"] # State "album" of "MightMini iTunes"
%%d:1604256801:album%%
For lights (dimmers) and appliance modules (relays or On/Off devices), you see On/Off/Brightness Controls
tile:
If the device doesn't support dimming, those controls will be hidden. You'll also notice that in the Device Details tile, On State
and Brightness
(if it's a dimmer) will show the current values.
For lights that allow users to set the color, you'll see the Color Controls
tile:
color_controls_tile
The top row of controls allow you to turn the light On, Off, and the last text field will allow you to type in the brightness (0-100). The second row of controls allows you to set the color and if the light supports it, the white value (also 0-100). If the light doesn't support setting white separately, the slider and text field will not show. The last row will allow you to se the temperature of the white (again, if the light supports it). If the light doesn't allow setting temperature, the Send Status Request
button will show instead.
Also, some energy monitoring devices, such as the iMeter, keep running totals of energy usage that can be reset by the user. For those, a Reset
button will be placed next to the Total Usage in the Device Details
tile.
Output Controls tile shows the state of all the output states available for the device and you can update them immediately using the Send Status Request
button. The button grid shows all available outputs and their status. Use the Turn Off All Outputs
button to turn off all binary outputs.
Enabled and Upload
- this means that it will be processed both while Indigo Server is running and it will be uploaded to your standalone controller (if it supports uploading).Enable
- this means that it will be processed while Indigo Server is running, and mirrors the Enabled column in the list if it's visible.Upload
- this means that it will only be uploaded and executed by your standalone controller (if it supports uploading) - while Indigo Server is controlling the logic it will not be enabledDisabled
- this means that it's completely disabled - it also mirrors the Enabled column in the list if it's available.
The Execute Conditional Actions
button will execute all the actions associated with the object, but only after any conditions specified in the Conditions tab are evaluated (so you can test the conditions).
The Execute Actions Only
button will do exactly that - execute all the actions associated with the object without evaluating any conditions specified in the Conditions tab.
The action group detail shows a list of all the actions in the group. The Execute Actions Now
button will do exactly that - execute all the actions associated with the action group.
The only thing in the detail area for a control page is the Show in Browser
button, which will open the selected page in the default browser.
Show Event Logs Folder
- this option opens the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 2023.1→General Settings…
and then selecting the General
tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside of that period of time.Clear Window
- this option clears the log entries from the Event Log window. The variable window is discussed in the Variables overview section.
About Indigo 2023.1
- this will show the About window which will show what client and server versions you're running and will show your registration codeStart Local Server…
- this will open the Start Server dialogStop Server
- this will stop the Indigo ServerConnect to Remote Server…
- this option will allow you to connect to a different Indigo server or a server running on another MacClose Connection
- this will close the connection to the serverGeneral Settings…
- this opens the preferences dialogAdvanced Web Server Settings…
- this opens the Indigo Web Server Settings dialogLicense Details…
- this opens the Subscription Status window that will show you the status of your License and it's associated Up-to-Date Subscription:
Check for Updates…
- this will have the server your connected to contact us to see if there is an update availableNew Database…
- this will close the current database and create a new one - you'll be prompted for a name and save locationSelect Database…
- this will allow you to switch to a different databaseClose Window
- this will close the frontmost windowNew Device…
- this will switch the Home Window to the devices view and open the new device dialogNew Trigger…
- this will switch the Home Window to the triggers view and open the new trigger dialogNew Schedule…
- this will switch the Home Window to the schedules view and open the new schedule dialogNew Action Group…
- this will switch the Home Window to the action groups view and open the new action group dialogThe Edit menu has the standard options on it that you would expect any Mac app to have. Note that the Delete and Duplicate options are available for most items in the user interface.
Home Window
- this will show/bring to front the Home WindowEvent Log
- this will show/bring to front the Event Log WindowVariable List
- this will show/bring to the front the Variable List WindowThe bottom of the menu will display the list of open windows, where the name of the active database will replace “Home Window”.
Help for XXXX
- this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular itemHow-To Wiki
- this will change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)Email Log…
- this option emails some of your event log data to the specified email address. Particularly useful for technical supportShow AppleScript Usage in Event Log
- this option prints a list of AppleScripts that are embedded in actions that you have specified. This will help to identify and replace those scripts.Show Event Logs Folder
- this option will switch to the Finder and open the folder that contains the Event Log log files.Show Web Assets Folder
- this option switches to the Finder and open the folder that contains custom images, text files, etc., that you might want to give Indigo (and others) access to through the Indigo Web Server.Show Indigo Server Install Folder
- this option opens a Finder window that displays the folder of the currently running Indigo installation. This will only run from the server machine (you'll receive a warning otherwise).Indigo Documentation
- this option will open your browser to the landing page for all Indigo 2023.1 documentationGetting Started Guide
- this option opens your browser to the Getting Started Guide, the place where everyone new to Indigo should startManaging a Z-Wave Network
- this option opens a browser window to the Managing Your Z-Wave Network document in our Documentation wikiManaging an INSTEON Network
- this option opens a browser window to the Managing Your INSTEON Network document in our Documentation wikiOnline Support Forum
- this option opens your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as wellCompatible Devices
- this option opens a browser window on our new Compatible Devices list that shows which devices and interfaces have been tested with Indigo and includes devices supported by 3rd party pluginsPlugin Store
- this option opens your browser to our Plugin Store where you can browse and download hundreds of 3rd party plugins that add functionality to IndigoZ-Wave® is a registered trademark of Sigma Designs, Inc. Indigo's support of Z-Wave hardware is neither endorsed nor certified by Sigma Designs.
