DEVICES
(or one of it's subfolders) from the Outline ViewNew…
buttonCreate New Device
dialog, select Timers and Pesters
from the Type:
popupTimer
from the Model:
menuConfigure Timer
dialog, specify the amount of time the timer will default to when started and the time incrementsSave
Create New Device
dialogThe timer device you created has 6 device states:
Timer Start Value
- the default value of the timer when the Start Timer
action is selected. It's set when you create a timer device and may be modified either via the device dialog or by using the Set Timer Start Value
action.Timer Status String
- a human-readable string representing the state of the timer. This is what's shown in the “State” column in the device table and can be displayed in a control page. The format is this: “Active with D:HH:MM:SS left”, “Paused with D:HH:MM:SS left”, “Inactive”.Timer Status
- the status of a timer in a way that's useful for image selection, scripts, etc. Values are one of: “inactive”, “active”, “paused”.Time Left in Seconds
- the amount of time remaining in seconds for the timer. Inactive timers will have a value of 0.Time Left in Minutes
- the amount of time remaining in minutes for the timer. Inactive timers will have a value of 0.Time Left in Hours
- the amount of time remaining in hours for the timer. Inactive timers will have a value of 0.Time Left in Days
- the amount of time remaining in days for the timer. Inactive timers will have a value of 0.There are two things you need to do to use a timer: control the timer (start, stop, pause, etc.) and trigger when a timer expires (when it runs out of time naturally as opposed to being stopped intentionally).
Start Timer
- use this action to start a timer. The timer device will automatically start counting down and the state will change. When the countdown completes, the status will be set to “inactive” and any triggers that are triggering off of the Timer Expired
event for this timer will be fired. The action will only start the timer when it's inactive and will be ignored when in any other state.Restart Timer
- use this action to restart a timer using the default time set for the timer. The action will always work regardless of the timer's current state.Pause Timer
- as the name implies, this action will pause the selected timer. The amount of time will not be modified so that you can resume the timer at will. The action will only pause an active timer and will be ignored when the timer is in any other state.Resume Timer
- use this action resume a previously paused timer. The action will only resume a paused timer and will be ignored when the timer is in any other state.Stop Timer
- use this action to stop a timer prematurely. The state becomes “Inactive” and all the time left states will be set to 0. It will not cause any Timer Expired
triggers to fire. The action will be ignored if the timer is already inactive.Set Timer Start Value
- use this action to set the default timer value without actually starting the timer. If the timer is running when it has it's start value changed, it will stop running.
There is also one custom event that you can use in a Trigger: Timer Expired
. This allows you to easily know when a timer runs out of time versus when it's explicitly stopped (by the Stop Timer
action described above). This is synonymous to when a kitchen timer starts beeping/ringing: if it runs out of time it rings but if you expressly turn it off then it doesn't.
TRIGGERS
buttonCreate New Trigger
dialog, select Timers and Pesters Event
from the Type:
popupTimer Expired
from the Event:
menuConfigure Timer Expired
dialog, specify the timer to watchSave
Create New Trigger
dialogSo, what else would you do with the timer aside from triggering off of it's expiration? You can display the various states on a control page and use those states in triggers and conditions as well. You could also show the countdown on a control page if that information is useful. You could even have an audio countdown by speaking the time left on the timer.
Another very useful feature of this plugin is the “Create Pester” action. This action will create a little mini timer which will repeat a specified number of times, executing an action group each time through and will execute an optional action group at the end of it's final occurrence. So - say you want to have your computer announce that it's time to take out the trash. However, if you're like me, once is never enough - I need to be nagged about it several times. Create a pester that repeats every 30 seconds for 5 times (so it doesn't go forever) that executes an action group that tells you to take out the trash. The final time can send an SMS to your phone.
Action id: startTimer
t_id = "com.perceptiveautomation.indigoplugin.timersandpesters" # Get a plugin object given the plugin id: timerPlugin = indigo.server.getPlugin(t_id) if timerPlugin.isEnabled(): timerPlugin.executeAction("startTimer", deviceId=1604521627)
Action id: pauseTimer
t_id = "com.perceptiveautomation.indigoplugin.timersandpesters" # Get a plugin object given the plugin id: timerPlugin = indigo.server.getPlugin(t_id) if timerPlugin.isEnabled(): timerPlugin.executeAction("pauseTimer", deviceId=1604521627)
Action id: restartTimer
t_id = "com.perceptiveautomation.indigoplugin.timersandpesters" # Get a plugin object given the plugin id: timerPlugin = indigo.server.getPlugin(t_id) if timerPlugin.isEnabled(): timerPlugin.executeAction("restartTimer", deviceId=1604521627)
Action id: resumeTimer
t_id = "com.perceptiveautomation.indigoplugin.timersandpesters" # Get a plugin object given the plugin id: timerPlugin = indigo.server.getPlugin(t_id) if timerPlugin.isEnabled(): timerPlugin.executeAction("resumeTimer", deviceId=1604521627)
Action id: stopTimer
t_id = "com.perceptiveautomation.indigoplugin.timersandpesters" # Get a plugin object given the plugin id: timerPlugin = indigo.server.getPlugin(t_id) if timerPlugin.isEnabled(): timerPlugin.executeAction("stopTimer", deviceId=1604521627)
Action id: setTimerStartValue
Properties for scripting:
timer | the ID of the timer device |
amount | a positive integer representing the initial countdown amount |
amountType | one of the following that represents the units of measure of the amount field: “seconds”, “minutes”, “hours”, “days” |
t_id = "com.perceptiveautomation.indigoplugin.timersandpesters" # Get a plugin object given the plugin id: timerPlugin = indigo.server.getPlugin(t_id) if timerPlugin.isEnabled(): timerPlugin.executeAction( "setTimerStartValue", deviceId=1604521627, props={ 'amount':'30', 'amountType':'minutes'} )
