The Indigo 7.4 application can be found here:
/Applications/Indigo 7.4.app
/Library/Application Support/Perceptive Automation/Indigo 7.4/
By default database files are stored in the Databases
folder in that folder.
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 7.4 installer again (which will repair any permission issues that Time Machine may have introduced).
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and ealier), the installer moves previously installed control page images and web server plugins to the new install location.
Indigo 7.3→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7.3→Quit Indigo
menu item./Applications
Indigo 7.2→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7.2→Quit Indigo
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and ealier), the installer is now smarter and moves previously installed control page images and web server plugins to the new instsall location.
Indigo 7→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.Indigo 7→Quit Indigo
First, run the Indigo 7.4 installer. Then look through this list for any final actions.
/Library/Python/2.6/site-packages/
to /Library/Python/2.7/site-packages/
/Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
/Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 6, 5, 4, 3, or 2 files. They have been modified to run optimally under Indigo 7(.X).
When Indigo first opens an Indigo 7.3 (or earlier) database, it will go through the database and identify items that will need changing and items you should look at to ensure that it will continue to function. The Event Log will contain the necessary information about where you can find those items. You can also select the Help→Show AppleScript Usage in Event Log
menu item and Indigo will show you the list of those items in the Event Log window again.
[~your user home folder]/Documents/Indigo User Data/Scripts/
) to the new folder specified above if you modified or added new script or script attachment files.NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 1.x files. They have been modified to run optimally under Indigo 7(.X).
Indigo 7.4→License Details…
button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)/Library/Application Support/Perceptive Automation/Indigo 7.4/
(if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 7.4→License Details…
from the Indigo 7.4
/System/Library/Extensions/IndigoOverrides.kext
~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-client6.plist
~(your user folder)/Library/Preferences/Indigo 7 Client Prefs.indiPref
~(your user folder)/Library/Preferences/Indigo 7 Client Settings.indiPref
To uninstall older versions but leave 7.4 installed correctly, delete these:
/Applications/Indigo 7.3.app
/Library/Application Support/Perceptive Automation/Indigo 7.2/
/Applications/Indigo 7.2.app
/Applications/Indigo 7.app
/Applications/Indigo 6.app
Indigo 7.4
application (/Applications/Indigo 7.4.app
).Indigo 7
button in the connection status window.Indigo 7.4→Start Local Server…
menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application
radio button. This will automatically run the client/server as a single application. This requires that the Indigo UI always be running on your Mac - when you quit the Indigo 7.4 Client application (Indigo 7.4→Quit
) all Indigo event processing (triggers, schedules, scripts, etc.) will cease processing. This is not our recommended configuration.
Choose the Start and connect to Indigo Server
Use the Allow remote access
checkbox to enable remote access from other Macs and Web browsers.
Use the Enable iPhone, iPod Touch, and remote Web browser access
checkbox to allow Indigo Touch (must be downloaded from the iTunes App Store) and remote Web browser access from other computers. Any modern Web browser (Safari, Firefox, Opera) on any computer that has internet access to your server Mac will be able to control and check the state of your home.
Use the Enable remote RSS feeds
checkbox to turn on the RSS and Atom server feeds, giving you RSS/Atom access to the last modified time stamp of all Indigo Devices.
Use the Require authentication
checkbox to enable password protection for both remote Indigo Clients and Web browser access. It is highly recommended that you enable authentication and assign a strong password.
Use the Enable anywhere secure access
checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server.
Use the Log Device state history to SQLite or PostgreSQL
checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions.
Press the Start Server
button, or the Restart Server
button.
Indigo 7.4
application (inside /Applications/Indigo 7.4.app
) on the remote Mac.Indigo 7
on this remote Mac, then press the Connect to Remote Server…
button in the connection status window.Indigo 7.4→Connect to Remote Server…
menu item.IP address
button.
on the Settings
http://192.168.1.23:8176/
Download Latest Release
button, which will download the plugin..indigoPlugin
. Double-click that file.Install and Enable
button.Note if you see the error alert below that the “Plugin is not compatible” then the version of the plugin you installed is too new to run with your Indigo Server version. In this case the best solution is to upgrade your version of Indigo Server.
The Manage Plugins…
The Plugin Store
will open the Scripts folder (where you can install Python libraries) in the Finder (see Shared Classes and Methods in Python Files for details).
The Open Scripting Shell
menu. For instance, here's the BetterEmail plugin submenu when it's enabled:
Enable
to enable the plugin and Disable
to disable the plugin.Reload
menu item will reload the plugin and will only be present if the plugin is enabled. Enable debugging menus
item selected in the Plugins tab of the Indigo Preferences (and are discussed in that section).The next section contains:
Configure…
menu item will open a config dialog if the plugin has plugin-specific configuration items (if not or if the plugin is disabled, it will not be present). Show in Plugin Store…
menu item will open the plugin's entry in the Plugin Store in the default browser. If there is an available plugin update that will work on your version of Indigo, the menu title will be Download New Version…
which will also open the plugin's entry in the Plugin Store in the default browser so you can download the new version, and if there is an incompatible version the menu title will be Incompatible Version Available…
which will drop a sheet showing what version of Indigo is required to run the new plugin version. This menu item will always show, but if it's grayed out it means the plugin isn't from the Plugin Store.About…
menu item will always show the current version of the plugin and will always be enabled.Any sections below this are specific to the plugin and will contain commands that the plugin presents to the user. If the plugin is disabled, no additional sections will be displayed.
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 7→Preferences…
menu item discussed above.
checkbox will add two new menus to the plugin's menus: Reload in Debugger
will reload the plugin and connect to the selected debugger; Reload in Interactive Shell
will open a terminal window with a Python shell that's connected to the plugin so the developer can run commands and inspect arbitrary objects in the running plugin.Use debugger
popup is used to tell Indigo which debugger to start the plugin up when you use the above menu items. See the Python Debugger Support forum post for further details on how to use these features to aid in developing a plugin.
Indigo 7.4→Stop Server
menu item in the Mac client (you can leave the client app running)./Library/Application Support/Perceptive Automation/Indigo 7.4/
(you can select the Go→Go to Folder…
menu item in the Finder and paste in the path to open a Finder window). In that Finder window you'll see two folders: Plugins
and Plugins (Disabled)
. Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin.Start Local Server…
button in the Server Connection Status
dialog.The plugin will no longer show in the Plugins tab or in the Plugins menu.
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as jetsons-house@myisp.com. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server
options shown below to reduce mailbox clutter.
menu item, then make sure the Email
tab is selected.Reply-to email address
field. Note that some SMTP mail servers are configured to not send emails unless the reply-to address specified matches the email address for the account. If mail sending fails, then make sure that the reply-to email address matches the email address for your account.Indigo 7→Preferences…
tab is selected.Check email every
checkbox.Delete from server emails that trigger actions
to have Indigo automatically remove any email messages that cause Indigo to trigger an action from your mail server. You should only use this option if Indigo has a dedicated email account.Delete from server all emails
to have Indigo automatically remove all email messages from your mail server. You should only use this option if Indigo has a dedicated email account.Once the Preferences dialog is closed, Indigo will automatically connect to your mail server to scan messages. This will happen within 10 seconds from the time the Preferences dialog is closed. Watch the progress bar in the main window and look for error messages in the Event Log Window to verify that Indigo was able to correctly connect.
To have Indigo send an email, create a Send Email
action.
To execute an action based on a scanned email, create an Email Received
trigger.
System Preferences
from the Apple
menu.Date & Time
icon.Time Zone
panel.Closet City
Indigo 7.4→Preferences…
checkbox.Latitude
and Longitude
coordinates.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 7→Preferences…
tab.
You can have Indigo check for updates immediately by selecting the Indigo 7→Check for Updates…
menu item.
System Preferences
from the Apple
menu.Energy Saver
icon.Computer sleep:
slider to Never
checkbox.Congratulations! You should now have a basic functioning Indigo installation that's ready for you to start adding devices and defining your home automation logic. We suggest that you next go to the Overview of Devices, Triggers, Schedules, Action Groups, Control Pages, and Variables - that will give you the information you need to begin using the features of Indigo.
