When you're ready to send a notification, you just add a “Notification” action and adjust it's options via the action config dialog:
† - the title and description fields may contain substitution markup. So, as you can see from the example above, we're substituting the value of variable ID 867446802 in the title and variable ID 264884531 in the description. See Substitutions for more information.
Action id: notify
Properties for scripting:
type | the string key of the notification type, must be one of: 'notification1', 'notification2', 'notification3', 'notification4', 'notification5', 'notification6', 'notification7', 'notification7' and must be enabled in the preferences (see preferences above) |
title | the title of the growl notification |
descString | the full text of the notification |
priority | the optional number priority for the notification: -2 (very low) through 2 (emergency) - defaults to 0 (normal priority) |
sticky | optional boolean that will cause the notification to stick (not automatically disappear) - defaults to False |
growlPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.growl") if growlPlugin.isEnabled(): growlPlugin.executeAction("notify", props={'type':"notification1", 'title':"Growl Title", 'descString':"Description of Growl Notification", 'priority':0, 'sticky':False})
