The NOAA Weather Plugin allows you to create Weather Station devices. To create a new one, switch to the device view and click the New…
button. This will bring up the device edit dialog. Select Plugin
from the Type:
popup. Select NOAA Weather
from the Plugin:
popup, and select Weather Station
from the Model:
button and you'll see the Weather Station Config UI. Enter the NOAA station id in the text box at the top. You can click on the “Find NOAA Stations” to have a browser window open to the NOAA webpage where you can start your search.
Observation Date/Time
- The last time the data was updated by NOAA. This field is in RFC822 Date/Time format (i.e. “Fri, 19 Aug 2011 11:51:00 -0500”) so it can be parsed by other software if needed.Current Condition
- The current condition in a word or twoCurrent Condition Icon
- The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA)Visibility
- Visibility in milesTemperature °F
- Temperature in FahrenheitTemperature °C
- Temperature in CelsiusTemperature String
- Temperature in a human-readable string (i.e. “98.0 F (36.7 C)”) - this is the state shown in the “State” column for a Weather Station deviceRelative Humidity
- The relative humidityDew Point °F
- Dew point in FahrenheitDew Point °C
- Dew point in CelsiusDew Point String
- Dew point in a human-readable stringHeat Index °F
- Heat index in FahrenheitHeat Index °C
- Heat index in CelsiusHeat Index String
- Heat index in a human-readable stringWind Direction
- Wind direction description in something close to human-readable formWind Degrees
- Wind direction in degreesWind MPH
- Wind speed in miles per hourWind Knots
- Wind speed in knotsWind String
- A description of the wind in human-readable formPressure (inches)
- Pressure in inchesPressure (mbar)
- Pressure in millibarsLocation
- Location in human-readable formLatitude
- LatitudeLongitude
- LongitudeHere's the plugin ID in case you need to programmatically restart the plugin:
