NOAA Weather
Plugin Config
Device States
  • Observation Date/Time - The last time the data was updated by NOAA. This field is in RFC822 Date/Time format (i.e. “Fri, 19 Aug 2011 11:51:00 -0500”) so it can be parsed by other software if needed.
  • Current Condition Icon - The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA)
  • Relative Humidity - The relative humidity
  • Latitude - Latitude
  • Longitude - Longitude
Scripting Support
Support and Troubleshooting
indigo_7_documentation/plugins/noaaweather.txt · Last modified: 2019/01/26 00:10 (external edit)
