The MorningLinc RF Controller has an additional INSTEON security feature which requires special linking steps. Specifically, you must use the technique of holding the MorningLinc's SET button when defining it and not try entering the INSTEON address directly into Indigo. To define the MorningLinc device in Indigo:
File→New Device…
menu item to create a new Indigo device.Define and Sync…
button inside the device dialog.Start
button.That will complete the process of defining an Indigo Device for the MorningLinc. However, the MorningLinc does not appear to respond to direct Turn On and Turn Off commands from Indigo. Instead you must create individual PowerLinc links to the Morninglinc (1 for lock and 1 for unlock):
Manage PowerLinc Links
from the Interface
menu.PowerLinc Group/Scene
number from the popup, and optionally give it a name such as “MorningLinc Unlock.”responder
. A sheet will drop down, explaining that you can't remotely program the MorningLinc, but that the PowerLinc is now in linking mode.Finished
button in the drop down sheet.You must next repeat the steps above for the other lock/unlock state.
You'll want to select a different PowerLinc Group/Scene from the popup (step #2), and you'll want to put the MorningLinc into the opposite lock/unlock state for step #4. Addendum: We've had reports of successfully reusing the same PowerLinc Group/Scene for the unlock state. Apparently the trick is to put the MorningLinc into the unlocked state then double tap (instead of single tap) the SET button before holding it down for 3 seconds.
That's it. You can now use the 2 PowerLinc Scenes (or single PowerLinc Scene if you followed the modified addendum notes) to send commands to the MorningLinc to unlock and lock it.
