The Indigo Reflector Service
About Reflectors
Indigo Reflectors is a service that gives you secure (HTTPS) remote access from anywhere to your Indigo Server with no network configuration needed. This is particularly useful for those of us that have dynamic (vs. static) IP addresses at home, or that have routers or networks that are difficult to configure for remote access to your Mac running Indigo.
Reflectors provide:
  • Hassle free setup:
Getting Started
Enabling a reflector is fast and easy. First, make sure you are running Indigo version 7.0.0 or greater(both client and server – check the About Box). Next:
  2. Turn on the Require authentication checkbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet.
Resetting Your Reflector's Activation
  1. Shut down the Indigo Server (select Indigo 7→Stop Server or Indigo 6→Stop Server if you're still on Indigo 6) but don't quit the Indigo Client
  2. Go to the reflector list in your Indigo Account and click the Reset link beside your reflector's status (it should say Activated before your press Reset).
  3. Switch back to the Indigo Client and click on the Start Local Server button
Manual Reset
If the procedure above doesn't work, and if instructed by support, follow these steps to manually reset your Indigo Client reflector settings:
  1. Shut down the Indigo Server (select Indigo 7→Stop Server) but don't quit the Indigo Client
  2. In the Finder, select Go→Go to Folder…
  3. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 7/Preferences/
  4. In the resulting Finder window, delete the folder named PrismReflector
  5. Switch back to the Indigo Client and click on the Start Local Server button
Bandwidth Limits
reflector/about.txt · Last modified: 2018/01/04 20:15 by jay
