Indigo Plugin Developer's Guide v1.1
Indigo Plugins and APIs
Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start. Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
A couple of problems with this though: the scripts in the Scripts folder were a mix of scripts installed by Indigo and user-installed, the images and plugins for IWS were buried in the IndigoWebServer folder. This led to confusion about how to upgrade.
With Indigo 5.0, we also wanted to add some new functionality: the ability for Indigo to launch scripts at startup and optionally keep them running (if they quit), a better way to encapsulate multiple parts to a solution (for instance, some AppleScripts that also had some additional control page images), a way to easily disable/enable various solutions without having to restart the server, and, most importantly, a new server plugin API that would allow 3rd party developers to more natively add devices, events (triggers), and actions to Indigo.
This new server API would allow users and 3rd party vendors to implement their own functionality in Python with full access to all the objects and events that Indigo understands (referred to as the Indigo Object Model, or IOM). Finally, users wouldn’t have to wait for us to add support for, say, the Global Caché IR devices, the THUM devices from Practical Design, etc. Someone with sufficient skills could implement support for those devices, have them integrated into the Indigo UI as first-class citizens. No strange variable state hacks, fake X10 devices, etc. - these new devices are actually recognized as real devices in Indigo.
What’s more, we wanted to ensure that Python programmers have complete access to everything that AppleScript scripts have access to. While AppleScript is a good language for a lot of things (and we aren’t dropping support for it) we believe that using a more modern, standard, capable, and platform agnostic scripting language is much better for our users in the long run.
FIXME add a common terms (glossary) Indigo IndigoServer plugin host plugin base class
So, given all of these goals, we’ve made some changes to the Indigo support folder structure and introduced a new concept: the Indigo plugin bundle. First, let’s look at the new Application Support folder structure.
Back to Top
Indigo has always supported customization by the user via various folders in the main Indigo directory located here:
/Library/Application Support/Perceptive Automation/Indigo 4
Located inside this folder were several sub-folders where users could put various scripts, web plugins and images. In Indigo 5.0, we changed the folder structure such that it looks like this:
New Support Folder Structure Image
The first thing you’ll probably notice are the two new folders: Plugins and *Plugins (Disabled)*. These two folders are where the new plugin bundles are stored (see the next section for details). Plugins that are enabled from the UI are located in the Plugins folder and when a user disables a plugin it’s moved to the *Plugins (Disabled)* folder.
Another new folder is the Images folder - this folder mirrors the old folder structure for images that was buried in the IndigoWebServer folder. FIXME: The images in this folder will be prefixed with the string user/ so that they will be distinguishable from images that are included by default with Indigo.
Those who are familiar with previous versions of Indigo will notice a few folders are gone - these have been moved/replaced/superseded. As the developer of some kind of Indigo extension, you’ll really only be interested in what you put into the Plugins folder, and that’s our next topic.
Back to Top
The Indigo Plugin Bundle
One of the biggest problems with extending Indigo was that there were pieces/parts all over the Application Support folder. As the developer of a solution, you often had to tell people to put various parts of your solution in various places, which of course has a huge margin for user error. To address that problem, we’ve created a new bundle type, the Indigo plugin bundle (.indigoPlugin), which has a very specific structure:
Bundle Picture Image
The first thing you’ll notice is that this is actually a real Finder bundle - so it appears to be a single file called Example.indigoPlugin. It’s moved around and treated as a single file, and all the user has to do to install your solution is to drag the plugin file (bundle) to the Plugins folder.
First, though, you can see that there is only one top-level folder in the bundle - Contents. All other files/folders are inside that folder. This is the standard Mac OS bundle construction, so we decided to follow the pattern.
The Info.plist File and the Resources Folder
Editing a plist file isn’t difficult, but it’s much easier using the Property List Editor application that Apple ships with the Xcode tools. However, it is just a text XML file that looks like this:
<plist version="1.0">
<dict>
    <key>PluginVersion</key>
    <string>1.0</string>
    <key>ServerApiVersion</key>
    <string>1.0.0</string>
    <key>IwsApiVersion</key>
    <string>Example Indigo Plugin</string>
    <key>CFBundleIdentifier</key>
    <string>com.yourdomain.plugin</string>
    <key>CFBundleVersion</key>
    <key>CFBundleURLTypes</key>
    <array>
        <dict>
            <key>CFBundleURLName</key>
            <string>http://www.yourdomain.com/plugin/</string>
        </dict>
    </array>
</dict>
</plist>
In Property List Editor, it looks like this:
Info Plist Property List Editor Image
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required.
  • ServerApiVersion - this is the version of the server plugin API as defined by us - for Indigo 5.0, it is 1.0.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • IwsApiVersion - much the same as the server plugin version (and defined by us), the web server plugin API is also now versioned - it’s also 1.0.0 with 5.0. This key is only required if your plugin implements a web server plugin.
  • Bundle display name (CFBundleDisplayName) - this is a standard Mac OS X key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.
  • Bundle identifier (CFBundleIdentifier) - this is another standard Mac OS X key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. This key is required.
  • Bundle version (CFBundleVersion) - another standard Mac OS X key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 5.0 it will be 1.0.0. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. In the UI, a help button will be present when a user is looking at the description of your plugin, and if clicked, the user’s browser will open to this URL. Note - this can be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
We want the user experience to be very similar for plugins, at least until it comes to configuration and use of the plugin, so you should be careful to get the Info.plist correct. We will be supplying a Mac application that will help you identify errors in the Info.plist as well as other parts of your plugin.
One of the folders, Resources, is also used for general information about your plugin. FIXME: For this version of the bundle, there should be only one file in there: Description.html. This file, as it’s name implies, is a nice HTML description of your plugin. It isn’t a full HTML file, though - it’s really just some very simple marked up text. No CSS, JavaScript, etc is allowed. You can do link (a href) and image (img) tags, as well as standard HTML style tags like strong and em. This description is going to be displayed in a pretty small view embedded in a dialog box - so be sure to test it thoroughly to make sure that it looks good when viewed in the Indigo Client.
The Scripts Folders
The plugin bundle contains several folders that are (almost) directly parallel the folders in the old Indigo application support Scripts folder.
Attachment Scripts
This folder functions exactly like the old one did - any script that's in this folder will have it’s handlers exposed inside the IndigoServer’s (IS) AppleScript context. When a plugin is disabled, IS will reload all the other active plugins Attachment Scripts folder excluding your plugin - so it’s quite important that you don’t create two plugins that have script dependencies. Each plugin should function completely and self-contained.
Background Items
The purpose of this folder is similar to the old Background Tasks folder. However, it’s much better than the old version: when IS loads the plugin, it launches all the scripts in this folder, and it monitors them to make sure they keep running. If one of these scripts stops running, IS will start it up again.
FIXME: Another bit of news here - these scripts can also be any script file that has the standard shell search string as the first line:
#!/usr/bin/env Python
If you’re using Python, the script will have access to the Indigo Object Model (IOM). FIXME: Really??
Launch Items
This folder works almost exactly the same way as the Background Items folder, but with one critical difference - any script in this folder is run at plugin start time, but IS won’t try to keep it running. The scripts in this folder would be used to initialize some aspect of your plugin. For instance, if your other scripts require a specific Indigo variable to be in place, you can have a script in this folder create the needed variables (if they don’t already exist) and populate them with valid values. The scripts in this folder may also be AppleScripts or any shell script.
This folder takes the place of old functionality. Before Indigo 5.0, if you put an AppleScript inside the Scripts folder (but not in any of the sub-folders), that script showed up in the Scripts menu in the Indigo Client. However, there is no more Scripts menu - it’s been replaced with a menu which contains submenus for each plugin. That submenu, specific to your plugin, will have all the scripts in this folder (minus the extension) added to it. So, it’s an easy way to add functionality to Indigo without having to write a full server plugin.
That pretty much covers the folders that would have scripts of various types in them. The functionality is a superset of the old Scripts folder and is plugin specific so your solution is now more integrated and easier for the user to deal with.
The Indigo Web Server (IWS) Plugin Folder
Another folder, IWS Plugin, may look familiar to you. In previous versions of Indigo, you created a folder in the plugins directory of the IndigoWebServer folder. The contents of this folder were also well defined: it has a reqhandler.py file, maybe a static, templates, and css folder, etc. Well, IWS plugins are now encapsulated inside the IWS Plugin folder in your bundle.
Now, you may be wondering - since it says IWS Plugin, does that mean that it’s only one plugin? The answer would be yes. We believe that an IWS Plugin encapsulate all related functionality - it should operate without the need for any other plugin and within a fixed context. Also, since you have the ability to have as many request handlers as you need, it seems appropriate that you have only one IWS plugin per bundle. We’ll discuss building an IWS Plugin in a later chapter.
FIXME what does the path look like in the browser to the IWS plugin?
The Images Folder
The Images folder mirrors the old IndigoWebServer/images folder. Images available in this folder will be available in the graphical control page editor. Just as a reminder, here’s how that folder is constructed and how the images are used:
  • backgrounds - put images here that you want to use for control page backgrounds
  • controls - in this directory, there are 3 more:
    • devices - in this directory, put in images to represent devices. In Indigo 4.1 and higher, we've added some heuristics that will allow you to add many more images. See Image Selection Heuristics below for details.
    • static - in this directory, you can just put static images that are shown when you select Static Image / Caption from the Display: popup in the control page editor.
    • variable - in this directory, you can put images that represent variables. In Indigo 4.1 and higher, we've added some heuristics that will allow you to add many more images. See Image Selection Heuristics for details.
Back to Top
As we explained earlier, there can only be one IWS Plugin per plugin bundle. Since an IWS Plugin can handle multiple request types (identified on the URL) either by defining several handlers:
it seemed likely that most plugin functions could be implemented in a single IWS Plugin. We’ll revisit if we need to in a later release. FIXME discuss where to add the name part of the plugin’s URL.
So, how do you implement an IWS Plugin? Not unlike the plugin bundle in which it resides, an IWS Plugin requires a very specific layout of files/folders in its directory. Namely, something that looks like this:
IWS Plugin Folder Overview Image
  • *css* - store CSS files used in templates or static pages (see below for details on templates)
  • *images* - store image files in this directory
  • *js* - store javascript files in this directory
  • *static* - store any static HTML files that your plugin would like to serve. For instance, you might want an about HTML file that gets displayed when the user selects a help link.
  • *templates* - store template files here (see below for details on templates)
The ***init**.py* file is unused, but it’s required - it can just be empty. The meat of the functionality is in the reqhandler.py. The structure of this file goes something like this: imports, static hook methods, request handler class.
  • *PlugInName()* - this method should return a string with a human readable name for your plugin. It will be used in the Event Log when the plugin loads and will (optionally) be shown on the IWS index (landing) page.
  • *PluginDescription()* - this method should return a string with a human readable description of what your plugin does. This will (optionally) be shown on the IWS index (landing) page. to the right of the name specified above.
  • *ShowOnControlPageList()* - this method should return true if you want your plugin listed on the IWS index page (using the name and description above). If you want your plugin to show up there, you’ll need to make sure you implement an index method in your handler class (described below) so that when the user clicks on the name of your plugin in the list the index page will load.
  • *IndigoConnected()* and *IndigoDisconnected()* - these methods are called just when their name implies - when IWS connects and disconnects from the IndigoServer process. Use these methods if you need to initialize and/or deallocate resources of some type.
The plugin request handler must subclass from BaseRequestHandler and must call the parent class ***init*** method:
def __init__(self, logFunc):
def index(self):
    return thePage
index.exposed = True    # exposed = True must be set for handler func to be called
index.exposed = true
<table>
    <tr>
    </tr>
    #set $i=1
    #for $deviceKey in $totalKeys
       #if (($i % 2) != 0)
         <tr class="darkRowBg">
       #else
         <tr class="lightRowBg">
       #end if
       #set $i=$i+1
      </tr>
    #end for
</table>
    tmpl.totals = totals
    tmpl.totalKeys = totalKeys
    return tmpl.RenderTemplate()
finally:
    tmpl.ReleaseLock();
finally:
    tmpl.ReleaseLock();
Back to Top
Indigo Server Plugins
The final and most comprehensive way to extend Indigo is the Indigo Server Plugin. This mechanism allows you to add native components such as device types, events, actions, and menu items. Because we didn’t want to make the server plugin mechanism dependent on any single OS architecture, we decided to implement them in Python and have the description and user interface for the plugins’ components described in HTML and XML files respectively. We chose Python for several reasons:
An important note here: Indigo uses Python v2.5. Python 2.7 is the default installation on Snow Leopard (2.5 is default on Leopard), and there are differences, so make sure that you're using Python 2.5 for your development or you could get a nasty surprise when you turn your code into a plugin (if you're developing code outside the plugin architecture). Snow Leopard does have 2.5 installed, it's just not the default install. It's in this directory:
Back to Server Plugins
The IOM is used for two similar purposes: scripting Indigo and building Server Plugins. They aren’t mutually exclusive, but they serve different needs. For instance, you may just want to write an embedded Python script action or condition vs building a full Server Plugin. Likewise, you may be interested in building a Server Plugin that doesn’t actually create any new device types, but simply adds events, actions, and menus to Indigo. This is fundamentally different from how AppleScript works with the IndigoServer.
FIXME here, we need to describe the old AppleScript embedded vs File concept and how it’s no longer necessary for IOM since IOM scripts will be run in a different process anyhow and the fact that Python scripts have to be executed within a specific environment to get access to IOM.
Indigo Plugin Host
More specifically, the IOM is presented to your plugin as a module, indigo, that all plugins automatically import. Every object that represents an Indigo object and every command that you use to communicate with Indigo is done through the indigo module. For example, to write something to the Indigo Log, you would do this:
Server Plugin Folder
Server Plugin Folder Image
Indigo Plugin XML Conventions
The Indigo plugin XML is formulated with a few rules that will help you navigate it’s constituent parts. Elements, such as Field, Action, Device, etc., will always start with a capitol letter. Attributes, such as id, type, defaultValue, etc, will always start with a lowerCase letter. Both elements and attributes will be camel case - that is, aside from the initial character described above, each new word will be capitalized.
Configuration Dialogs
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="0">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readOnly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="no">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="1">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Back to Configuration Dialogs
Text Field
    <Label>Text Field:</Label>
</Field>
Attribute Required Notes
defaultValue No You can enter a default value here.
enabledBindingId No If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field.
hidden No If this attribute is set to true then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user.
id Yes This is a unique identifier for this Field within the context of this ConfigUI element.
tooltip No Unfortunately, enabled text fields won’t show tooltips (Cocoa limitation), so your tooltip should probably tell the user why it’s disabled (since that’s the only time it’ll show) if the field is ever disabled.
type Yes This must be textfield.
visibleBindingId No If you want to conditionally show/hide this field based on the value of another field, set this value to the id of another field. If you set this, you must also include a visibleBindingValue
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to 0 will mean the text field is visible only when the checkbox is unchecked, and a 1 means the opposite. To make the field dependent on a list or menu, set this value to a comma separated list of option values (item1, item2). You can even bind it to the value in another text field, but that’s probably of limited use.
Configuration UI Menu Image
    <Label>Popup Menu:</Label>
</Field>
defaultValue No You can enter a default value here. The value must be one of the values from the List element described below.
hidden No If this attribute is set to “true” then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user.
tooltip No Unfortunately, enabled menus won’t show tooltips (Cocoa limitation), so your tooltip should probably tell the user why it’s disabled (since that’s the only time it’ll show) if the field is ever disabled.
type Yes This must be “menu”.
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to “0” will mean the menu field is visible only when the checkbox is unchecked, and a “1” means the opposite. To make the field dependent on a list or another menu, set this value to a comma separated list of option values (“item1, item2”). You can even bind it to the value in a text field, but that’s probably of limited use.
List
Configuration UI List Image
```xml
| *`defaultValue`* | No | You can enter a default value here. The value must be a comma separated list of values, each value must be listed as an option in the *`List`* element. |
| *`enabledBindingId`* | No | If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the *`id`* of that field. |
| *`hidden`* | No | If this attribute is set to *`true`* then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user. |
| *`id`* | Yes | This is a unique identifier for this *`Field`* within the context of this *`ConfigUI`* element. |
| *`tooltip`* | No | The tooltip will be shown when you hover over the actual list control. |
| *`type`* | Yes | This must be *`list`*. |
| *`visibleBindingId`* | No | If you want to conditionally show/hide this field based on the value of another field, set this value to the *`id`* of another field. If you set this, you must also include a *`visibleBindingValue`* |
| *`visibleBindingValue`* | No | If you specify a *`visibleBindingId`*, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to *`0`* will mean the menu field is visible only when the checkbox is unchecked, and a *`1`* means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of *`Option`* values (*`item1, item2`*). You can even bind it to the value in a text field, but that’s probably of limited use. |
Static list fields are constructed almost identically to static popup menu fields - with a *`Label`* element and a *`List`* element which contains multiple *`Option`* elements. Each *`Option`* element must have a *`value`* attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma characters. The text inside the *`Option`* element is what is displayed for each line in the user interface.
As with *`menu`* fields, you may also specify a list dynamically at runtime - that is, when the UI is created, the client will call into your plugin to get the list items. This will allow you to dynamically adjust the list items every time the UI comes up. You can also specify some built-in dynamic items that the IndigoServer will provide automatically for you. See the [#Dynamic Lists](#dynamic-lists) section below for details.
[Back to Configuration Dialogs](#configuration-dialogs)
#### Dynamic Lists
```python
</Field>
Class: indigo.devices
Optional Filters Description
indigo.relay relay devices
indigo.dimmer dimmer devices
indigo.sprinkler sprinklers
indigo.thermostat thermostats
Class: indigo.triggers
indigo.varChange variable changed triggers
    <List class="com.mycompany.myplugin" filter="stuff" method="myListGenerator"/>
</Field>
def myListGenerator(self, filter)
    # From the example above, filter = “stuff”
    # Create an array where each entry is a list - the first item is
    # show up in the control
    myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)]
    return myArray
</Field>
Checkbox
```xml What's on the right side of the checkbox
| *`id`* | Yes | This is a unique identifier for this Field within the context of this *`ConfigUI`* element. |
| *`type`* | Yes | This must be “list”. |
| *`defaultValue`* | No | You can enter a default value here. The value must be either *`yes`* or *`no`*. |
| *`visibleBindingValue`* | No | If you specify a *`visibleBindingId`*, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to *`0`* will mean the menu field is visible only when the checkbox is unchecked, and a *`1`* means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (*`item1, item2`*). You can even bind it to the value in a text field, but that’s probably of limited use. |
Checkboxes contain the standard required Label element. They also contain an optional element, *`Description`*, that’s used to deliver extra information on the right side of the checkbox. Many checkboxes may not need this extra information.
#### Label
![Configuration UI Label Image](images/configui_label.png)
```xml
<Field id="exampleLabel" type="label"
    </Label>
</Field>
type Yes This must be label.
visibleBindingValue No If you specify a visibleBindingId, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to 0 will mean the menu field is visible only when the checkbox is unchecked, and a 1 means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (item1, item2). You can even bind it to the value in a text field, but that’s probably of limited use.
Separator
<Field id="simpleSeparator1"
        type="separator"
        visibleBindingValue="1"/>
type Yes This must be separator.
Button
Configuration UI Button Image
```xml Visible Button Title ConfigButtonPressed
| *`type`* | Yes | This must be *`button`*. |
Aside from the standard *`Label`* element, the button field also contains two other required elements. The first is the *`Title`* element - this is the string that is displayed inside the button. The other required element is the *`CallbackMethod`* element, which contains the name of a Python method in your code that’s called when the user presses the button. This field type is read-only, which means that you can't have an error message attached to it from a validation method or a button method (see below for details).
The process flow is this:
1. A dictionary containing all the values of the fields in the dialog are sent to the method that you identify in the *`<CallbackMethod>`* element.
1. Your plugin can then do whatever it needs to and it returns a the dictionary back to the dialog containing any field changes.
Each button's method signature will match the parameters that are used in the validation methods described below. For instance, if you specify a method called "beginPairing" in a button field of the *`<ConfigUI>`* XML for a device like this:
```xml
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
action validateActionConfigUi(self, pluginProps, typeId, devId) typeId - action type specified in the type attribute \ actionId - the unique action ID for the action being edited (or 0 of it's a new action) \ *valuesDict* - the dictionary of values currently specified in the dialog
    return True
    return (True, valuesDict)
  3. An error dictionary. The keys will be the fieldId and the value will be the error string. When the dialog receives this return, it will turn each field with an error red and add a tooltip to the label part of the field so the user can mouse over the label to see what’s wrong.
    errorDict = indigo.Dict()
    return (True, valuesDict, errorDict)
Dialog Close Notification
Dialog Type Method Signature
The parameters are exactly the same as in the validation methods with the addition of userCancelled - which is a boolean. We're sure there are other reasons why one would need to know when the dialog closes so we wanted to make sure that the complete lifecycle of the dialog was exposed to you.
PluginConfig.xml
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 5/Preferences/Plugins/
Devices.xml
Name Type Required Notes
type Attribute Yes This must be one of: relay, dimmer, or custom. We’ll discuss each below.
typeId Attribute Yes This is your plugins unique identifier for this device type. It must be unique in this plugin.
DeviceTypeName Element Yes This is the name of the device type that users will see when selecting the type in the Devices dialog.
States Element No This element is only used for custom device types. It describes all the possible states for the device. See the description below for more details.
In this first iteration of our plugin API, we are going to allow you to define three types of devices: relay, dimmer, and custom. Relay and dimmer devices will share the common UI, states, actions that the corresponding INSTEON and X10 devices do.
FIXME: describe type and how it effects the control UI for the device
Relay Device Type
Relay devices are functionally equivalent to appliance modules - they support only one state: on state. They also support a status request. The definition of a relay device is pretty simple:
<Device type="relay" typeId="appliance">
    <DeviceTypeName>Appliance Module</DeviceTypeName>
    <ConfigUI>
        <SupportURL>http://www.yourdomain.com/plugin/relay.html</SupportURL>
        <Field id="autoLabel" type="label"
        </Field>
        <Field id="exampleButton" type="button" >
        </Field>
        <Field id="nodeID" type="textfield">
        </Field>
        <Field id="simpleSeparator1" type="separator"
                visibleBindingId="manualEntry" visibleBindingValue="0"/>
        <Field type="checkbox" id="manualEntry" defaultValue="no">
        </Field>
        <Field id="manualNodeID" type="textfield"
                visibleBindingId="manualEntry" visibleBindingValue="1">
        </Field>
    </ConfigUI>
</Device>
The device definition above will show the user the following when a new device is created in Indigo:
Devices Relay Dialog Image
When the user selects “Plugin” from the “Type:” menu, the “Plugin” and “Device” popups will be shown. When the user selects your plugin from the “Plugin” popup, a list of all the device types you’ve defined will be populated in the “Device” popup. The string in the <DeviceTypeName> element (see above) is what’s used for the menu items.
FIXME: insert the Python handling code here for turnOn, turnOff, statusRequest
Dimmer Device Type
Like a relay device, a dimmer device type will inherit the UI, actions, etc. that all other dimmer type devices have. They have two states: on state and brightness level. They also have a status query action. The XML for a dimmer device would look exactly the same as the XML for a relay except that the typeId attribute would be dimmer.
Custom Device Type
The custom device type is where the real action happens. Because it’s completely custom, you must specify everything about the device - it’s states and their types (Integer, Float, String, List (enumeration), Boolean). So, here’s a simple example of the <States> element of a custom device, in this case a thermostat:
    <State id="temperature" readOnly="YES">
        <ValueType>Float</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
id Attribute Yes This is a unique identifier for this State within the context of this Device element.
readOnly Attribute No If you want this state to be read only, set this attribute to “YES”. For instance, as in this example, the temperature the thermostat is sensing isn’t user settable. (Currently unused but it may be used in the future)
TriggerLabel Element Yes When selecting “Device State Changed” type trigger events, you can select your device in the resulting list. A popup below the device will list all of your States using this text. FIXME: Add image below
ControlPageLabel Element Yes In the Control Page Editor, when selecting “Device State” as the display type, then select your device, the next popup will show all your states using this text. FIXME: Add image below
FIXME: we also use this to create an ad-hoc control interface for devices of this type that will show up in the IWS pages as well as in Indigo Touch.
Events.xml
<Events>
    <Event eventId="updateAvailable">
        <Label>Plugin Update Available</Label>
    </Event>
</Events>
As you can see, your <Event> elements can define a <SupportURL> element as well - the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show.
Label Element Yes This is the text that’s shown in the trigger event dialog that represents this event.
FIXME need to add some Python examples of how to notify the server that one of these events has occurred
Actions.xml
<Actions>
    <Action actionId="resetInterface">
        <Label>Reset Interface</Label>
    </Action>
</Actions>
As with <Event>, your <Action> elements can define a <SupportURL> element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show.
Label Element Yes This is the text that’s shown in the actions dialog that represents this action.
FIXME Python example of a complete action method definition
<MenuItems>
    <MenuItem id="menu1">
        <Title>Reset Interface</Title>
        <Action>resetInterface</Action>
    </MenuItem>
    <MenuItem id="menu2">
        <Title>Check for Updates</Title>
        <Action>checkForUpdates</Action>
    </MenuItem>
</MenuItems>
id Attribute Yes This is a unique id for the menu item in this file.
Title Element Yes This is the text that’s shown in your plugin’s sub-menu.
CallbackMethod Element Yes This is the name of the method defined in your plugin that will be called when your user selects this menu item. \ \ Your method won’t be able to present any user interface as a result of the menu item being selected except for adding an entry to the event log. However, if the result of the menu execution is that an Event is fired (for instance, the update check above may fire any “update available” events described above that your user has defined) then those events will be executed in Indigo.
def checkForUpdates(self):
plugin.py
There are a few methods that the host process will call at various times during your plugins lifecycle, some required and others are optional:
General Plugin Methods
Name Required Notes
%%**init**%% Yes This method gets a dictionary of preferences that the server read from disk. You have the opportunity here to use them or alter them if you like although you most likely will just pass them on to the plugin base class: \ \ ```python
def init(self, pluginPrefs):
%%**del**%% Yes This is the destructor for the class. Again, you’ll probably just call the super class’s method: \ \ ```python
def del(self):
indigo.PluginBase.del(self)
startup No This method will get called after your plugin has been initialized. This is really the place where you want to make sure that everything your plugin needs to do gets set up correctly. It’s passed no parameters. If you’re storing a config parameter that’s not editable by the user, this is a good place to make sure it’s there and set to the right value. This is not, however, where you want to initialize devices and triggers that your plugin may provide - those are handled after this method completes (see the methods below). \ \ ```python
def startup(self):
indigo.server.log(u"Start called")
shutdown No This method will get called when the IndigoServer wants your plugin to exit. If you define a global shutdown variable, this is the place to set it. You’ll use it in the next method. Other things you might do in this method: if your plugin uses a single interface to talk to multiple devices, this is the place where you would want to shut down that interface (close the serial port or network connection, etc). Each device and trigger will already have had a chance to shutdown by the time this method is called (see the methods below). \ \ ```python
def shutdown(self):
`` Note: *shutdown* will be called after *runConcurrently* (discussed next) so cleanup here will be after any changes that might result from a loop in *runConcurrently`*.
runConcurrentThread No This method is called in a newly created thread after the Start method finishes executing. It’s expected that it should run a loop continuously until asked to shutdown. \ \ ```python
while True:
# Do your stuff here
self.sleep(60) # in seconds
except self.StopThread:
# do any cleanup here
pass
`` You must call *self.sleep()* with the number of seconds to delay between loops. *self.sleep()* will raise an *indigo.StopThread* exception when you should end *runConcurrentThread*. You don’t have to catch that exception if you don’t need to do any cleanup before returning - it will just throw out to the next level. Note: *shutdown* will be called after *runConcurrently`* finishes processing so you can do your cleanup there.
stopConcurrentThread No This method will get called when the IndigoServer wants your plugin to stop any threads that it may have created. The default implementation (below) will set the stopThread instance variable which causes the self.sleep() method to throw the exception that you handle in runConcurrentThread above. In most circumstances, your plugin won't need to implement this method. \ \ ```python
self.stopThread = True
Device Specific Methods
Name Required Notes
*deviceStartComm(self, dev)* No If your plugin defines devices, this is likely the place where you'll want to do the work of starting your device up. For instance, let's say that you have a device somewhere out on the network - the easiest way to "start" your device is to implement this method. You would open the network address:port (that's defined in *dev.pluginProps*), get it's current state(s) and tell the IndigoServer to set those states (using the *dev.updateStateOnServer()* method).
*deviceStopComm(self, dev)* No This is the complementary method to *deviceStartComm()* - it gets called when the device should no longer be active/enabled. For instance, when the user disables or deletes a device, this method gets called.
didDeviceCommPropertyChange(self, origDev, newDev) No This method gets called by the default implementation of deviceUpdated() to determine if any of the properties needed for device communication (or any other change requires a device to be stopped and restarted). The default implementation checks for any changes to properties. You can implement your own to provide more granular results. For instance, if your device requires 4 parameters, but only 2 of those parameters requires that you restart the device, then you can check to see if either of those changed. If they didn't then you can just return False and your device won't be restarted (via *deviceStopComm()*/*deviceStartComm()* calls).
*deviceCreated(self, dev)* No This method will get called whenever a new device defined by your plugin is created. In many circumstances, you won't need to implement this method since the default behavior (which is to call the *deviceStartComm()* method if it's your device and it's enabled) is what you want anyway (see the *deviceStartComm()* method above for details). However, if for some reason you need to know when a device is created, but before your plugin is asked to start communicating with the device, this method can provide that hook. If you implement this method, you'll need to either call *deviceStartComm()* or duplicate the functionality here. \ \ You can also have this method called for devices that don't belong to your plugin. If, for instance, you want to know when all devices are created (and updated/deleted), you can call the *indigo.devices.subscribeToChanges()* method to have the IndigoServer send all device creation/update/deletion notifications. Why? Maybe you're logging all device changes - or maybe you're managing a scene and need to know when the devices in your scene change. Subscribing to changes should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer.
*deviceUpdated(self, origDev, newDev)* No Complementary to the deviceCreated() method described above, but signals device updates. You'll get a copy of the old device object as well as the new device object. The default implementation of this method will do a few things for you: if either the old or new device are devices defined by you, and if the device type changed OR the communication-related properties have changed (as defined by the *didDeviceCommPropertyChange()* method - see above for details) then deviceStopComm() and deviceStartComm() methods will be called as necessary (stop only if the device changed to a type that isn't your device, start only if the device changed to a type that belongs to you, or both if the props/type changed and they both both belong to you).
*deviceDeleted(self, dev)* No Complementary to the *deviceCreated() method* described above, but signals device deletes. The default implementation just checks to see if the device belongs to your plugin and if so calls the *deviceStopComm()* method. If you implement this method you'll need to call *deviceStopComm()* yourself or duplicate the functionality here.
Trigger Specific Methods
Name Required Notes
*triggerStartProcessing(self, trigger)* No If your plugin defines events, this is likely the place where you'll want to do the work to start watching for those events to occur. For instance, let's say that you have an event for a plugin update, then you'll want to periodically check your site to see if there's a new version available. This is where you'd start that process.
*triggerStopProcessing(self, trigger)* No This is the complementary method to *triggerStartProcessing()* - it gets called when the event should no longer be active/enabled. For instance, when the user disables or deletes a trigger, this method gets called.
didTriggerProcessingPropertyChange(self, origTrigger, newTrigger) No Much like it's device counterpart above (*didDeviceCommPropertyChange()*), this method gets called by the default implementation of *triggerUpdated()* to determine if any of the properties needed for recognizing an event have changed. The default implementation checks for any changes to any properties.
*triggerCreated(self, dev)* No This method will get called whenever a new trigger defined by your plugin is created. In many circumstances, you won't need to implement this method since the default behavior (which is to call the *triggerStartProcessing()* method if it's your trigger and it's enabled) is what you want anyway (see the *triggerStartProcessing()* method above for details). However, if for some reason you need to know when a trigger is created, but before your plugin is asked to start watching for the appropriate conditions, this method can provide that hook. If you implement this method, you'll need to either call *triggerStartProcessing()* or duplicate the functionality here. \ \ You can also have this method called for triggers that don't belong to your plugin. If, for instance, you want to know when all triggers are created (and updated/deleted), you can call the *indigo.triggers.subscribeToChanges()* method to have the IndigoServer send all trigger creation/update/deletion notifications. As with other change subscriptions, this should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer.
*triggerUpdated(self, origDev, newDev)* No Complementary to the triggerCreated() method described above, but signals trigger updates. You'll get a copy of the old trigger object as well as the new trigger object. The default implementation of this method will do a few things for you: if either the old or new trigger are triggers defined by you, and if the trigger type changed OR the communication-related properties have changed (as defined by the *didTriggerProcessingPropertyChange()* method - see above for details) then triggerStopProcessing() and triggerStartProcessing() methods will be called as necessary.
*triggerDeleted(self, dev)* No Complementary to the *triggerCreated() method* described above, but signals trigger deletes. The default implementation just checks to see if the trigger belongs to your plugin and if so calls the *triggerStopProcessing()* method. If you implement this method you'll need to call *triggerStopProcessing()* yourself or duplicate the functionality here.
Schedule Specific Methods
Name Required Notes
FIXME add schedule stuff
Action Group Specific Methods
Name Required Notes
FIXME add action group stuff
Variable Specific Methods
Name Required Notes
*variableCreated(self, var)* No This method will get called whenever a new variable is created. You can call the *indigo.variables.subscribeToChanges()* method to have the IndigoServer send all variable creation/update/deletion notifications. As with other change subscriptions, this should be used very sparingly since it's a lot of overhead both for your plugin and, more importantly, for the IndigoServer.
*variableUpdated(self, origVar, newVar)* No Complementary to the variableCreated() method described above, but signals variable updates. You'll get a copy of the old variable object as well as the new variable object.
*variableDeleted(self, var)* No Complementary to the *variableCreated() method* described above, but signals variable deletes.
Method Parameters Return Value Notes
*applicationWithBundleIdentifier(self, bundleID)* *bundleID* - this is the bundle identifier for the app SBApplication instance Bundle id's are usually fully qualified strings - for iTunes it's com.apple.iTunes. What's returned is a scripting bridge SBApplication instance. See the Scripting Bridge documentation for more information.
*browserOpen(self, url)* *url* - the url to open in the browser None This method will open the specified in the default browser - obviously it does so on the server machine
*debugLog(self, msg)* *msg* - the string to insert into the event log None If, at any point in your plugin, you set *self.debug = True*, then any time debugLog is called the string will get inserted into Indigo's event log. If *self.debug = False* (the default) any call to debugLog does nothing.
*errorLog(self, msg)* *msg* - the string to insert into the event log None If you want an error to show up in the event log (in red text), use this log method rather than indigo.server.log().
FIXME should discuss the plugin flow for several types of plugins: with devices, events, actions - and plugins that use runConcurrentThread and plugins that start up threads, etc., so that it'll be easier to try and envision how to approach thinking about a plugin.
FIXME Discuss the prefs and prefs file (cached and written only periodically or when the plugin quits)
Back to Top
3rd Party Python Libraries
FIXME decide how much to put here
PySerial v2.5 - just "import serial" at the top of your script
