| api_release_notes:1.7 [2013/03/29 20:49] – mattb | api_release_notes:1.7 [2026/04/07 18:27] (current) – external edit 127.0.0.1 |
| | ====== API v1.7 Release Notes ====== |
| | This version of the API shipped with Indigo 6 beta 8 - check the [[:API Version Chart]] to see what version of the API is available in which Indigo versions. |
| | * Added //''indigo.server.apiVersion''// attribute which returns the Indigo Server's current plugin API version as a string (ex: "1.7"). The plugin can then use this value to add conditionals around calling newer APIs while maintaining backwards compatibility with older versions of Indigo Server. |
| | * Added //''dehumidifierIsOn''// and //''humidifierIsOn''// attributes to the thermostat device class. These attributes are set to True for some thermostats (2441TH, 2441ZTH) when their humidity setpoints are crossed to turn ON/OFF dehumidifiers and humidifiers. |
| | * Added //''updateTimeStampOnServer()''// method to device instances to increment last changed timestamp on a device. |
