Link to this comparison view
Next revision
Previous revision
api_release_notes:1.7 [2019/01/25 22:53] – external edit 127.0.0.1api_release_notes:1.7 [2026/04/07 18:27] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== API v1.7 Release Notes ======
 +This version of the API shipped with Indigo 6 beta 8 - check the [[:API Version Chart]] to see what version of the API is available in which Indigo versions.
 +  * Added //''indigo.server.apiVersion''// attribute which returns the Indigo Server's current plugin API version as a string (ex: "1.7"). The plugin can then use this value to add conditionals around calling newer APIs while maintaining backwards compatibility with older versions of Indigo Server.
 +  * Added //''dehumidifierIsOn''// and //''humidifierIsOn''// attributes to the thermostat device class. These attributes are set to True for some thermostats (2441TH, 2441ZTH) when their humidity setpoints are crossed to turn ON/OFF dehumidifiers and humidifiers.
 +  * Added //''updateTimeStampOnServer()''// method to device instances to increment last changed timestamp on a device.
