Link to this comparison view
Next revision
Previous revision
api_release_notes:2.4 [2020/11/12 00:45] – created mattbapi_release_notes:2.4 [2026/04/07 18:27] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== API v2.4 Release Notes ======
 +This version of the API shipped with Indigo 7.5.0 - check the [[:API Version Chart]] to see what version of the API is available in which Indigo versions.
 +  * Added new methods to get the plugin list //''indigo.server.getPluginList()''// and check if a plugin instance is installed //''plugin.isInstalled()''//.
 +  * Added optional //''level''// argument to the //''indigo.server.log()''// method to specify the python logging level that will determine the Event Log window text color used. Possible values include: //''logging.INFO''// (black), //''logging.WARNING''// (orange), //''logging.ERROR''// (red). The default plugin instance logger will also now map //''self.logger.warn()''// to use an orange text color as well. Example usage:
 +  import logging
 +  indigo.server.log("info log message which will show in black text", level=logging.INFO)
 +  indigo.server.log("warning log message which will show in orange text", level=logging.WARNING)
 +  indigo.server.log("error log message which will show in red text", level=logging.ERROR)
 +  # Equivalent of above server API calls that instead use the plugin instances default logger instance:
 +  self.logger.info("info log message which will show in black text")
 +  self.logger.warn("warning log message which will show in orange text")
 +  self.logger.error("error log message which will show in red text")
