| garage_door_kpl_control [2011/12/20 18:23] – jay | garage_door_kpl_control [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Control a Garage Door and have a KeypadLinc Show Garage Door Status ====== | ||
| + | A pretty frequent request is to have an [[http:// | ||
| + | The approach we're going to take in this scenario is using Insteon links to do all the work. We'll use Indigo to create the links and change some settings but after that Indigo won't be involved at all during normal operation. In this tutorial we're going to assume that we're linking to button 3 on your KPL (see [[inst_keypadlinc_buttons |KeypadLinc Buttons]] for details). So, first thing we want to do is configure some options on the I/O Linc and the KPL: | ||
| + | - Configure your I/O Linc Garage Door Kit as described in steps 1-3 of this [[iolinc_garage_door_alert# | ||
| + | - Configure your KPL button to always send ON commands regardless of the LED state. The I/O Linc expects an ON command to turn on the output momentarily to start your door opening or closing. In Indigo 6 you can do this with the **'' | ||
| + | At this point, you have your I/O Linc and your KPL button configured correctly. Now, we want to link the devices using Insteon links: | ||
| + | - Find your I/O Linc in the Devices list and double-click it. You'll see the **'' | ||
| + | - Click the '' | ||
| + | - Click the **'' | ||
| + | - In the **'' | ||
| + | That's it. The button LED may be incorrect now because it hasn't synced, so just press the button and let the door complete its cycle. Then do it one more time and let the door complete its cycle. The button state should now mirror the door state. If it's opposite from what you want (LED is ON when the door is open for example), then just switch the checkbox referenced above in the I/O Linc configuration section then run the cycle again and it should be in sync. | ||
