| indigo_2021.2_documentation:reflectors [2021/11/12 21:35] – [About Reflectors] jay | indigo_2021.2_documentation:reflectors [2025/04/14 20:10] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== The Indigo Reflector Service ====== | ||
| + | ==== About Reflectors ==== | ||
| + | [[http:// | ||
| + | Reflectors work by routing communication from [[https:// | ||
| + | Your purchase of Indigo includes an [[http:// | ||
| + | Reflectors provide: | ||
| + | * Personalized easy-to-remember URL when using [[http:// | ||
| + | * [[http:// | ||
| + | * 3rd party services like Amazon Alexa can get secure, authenticated access to your Indigo Server to open up a broad range of integration possibilities. | ||
| + | * Complete remote access solution (much more than just a dynamic IP address mapping service) | ||
| + | * Fully encrypted (256-bit) communication | ||
| + | * Hassle free setup: | ||
| + | * No firewall configuration needed | ||
| + | * No router port forwarding needed | ||
| + | * No static IP address or DynDNS account needed | ||
| + | * No non-standard port numbers to remember | ||
| + | * No reverse proxies to implement SSL/HTTPS | ||
| + | ==== Activating your Reflector ==== | ||
| + | Activating a reflector is fast and easy. First, make sure you are running Indigo version 7.0.0 or greater(both client and server -- check the About Box). Next: | ||
| + | - Choose the '' | ||
| + | - Turn on the '' | ||
| + | - Press the '' | ||
| + | A browser page will open to the http:// | ||
| + | * If you already have an Indigo Account then log in (if necessary). You'll then be redirected to the registration codes page. | ||
| + | * If you don't have an Indigo Account then create one by clicking on the '' | ||
| + | Once on the registration codes list page, you'll see a message to click the **Create Reflector** link next to your Indigo registration code. Click on that link and you'll switch to the Reflectors page with a form field to enter your reflector name. When you submit that we will create the reflector, activate it, and take you back to the codes page which will show your reflector activated. | ||
| + | Lastly, switch back to the Indigo '' | ||
| + | You can now access Indigo web pages from anywhere using your personalized URL. No firewall settings changes, router port forwarding, etc. is needed. And even if your IP address changes, Indigo will automatically make sure that a new connection is re-established within just a few minutes. | ||
| + | Your reflector will be active as long as you maintain an active Indigo Up-to-Date subscription. | ||
| + | ==== Reset Your Reflector' | ||
| + | If you are switching to a different reflector that you've asked us to create for you, or you've been instructed by support to reset your current reflector' | ||
| + | - Shut down the Indigo Server (select '' | ||
| + | - Switch to your browser and [[http:// | ||
| + | - Go to the [[http:// | ||
| + | - Switch back to the Indigo Client and click on the **'' | ||
| + | You should now see an '' | ||
| + | === Manual Reset === | ||
| + | If the procedure above doesn' | ||
| + | - Shut down the Indigo Server (select **'' | ||
| + | - In the Finder, select **'' | ||
| + | - In the resulting dialog, copy and paste the following: **''/ | ||
| + | - In the resulting Finder window, delete the folder named **'' | ||
| + | ==== Indigo Touch and Your Reflector ==== | ||
| + | [[http:// | ||
| + | Once Indigo automatically detects your reflector address, it will seamlessly change between using the local Bonjour detected address and the remote reflector address. Just launch Indigo Touch and it works, no matter where you are! | ||
| + | ==== Bandwidth Limits ==== | ||
| + | Because using a reflector has to bounce all requested files to and from our server, monthly bandwidth usage cannot be unlimited. Reflectors that exceed an average bandwidth of approximately 200 MB per day may have temporary limitations or throttles imposed, but a vast majority of the time bandwidth is not an issue. There are a couple of things that can lead to excessive bandwidth usage. So please consider: | ||
| + | * If you have a graphical Control Page in Indigo that uses the '' | ||
| + | * Not leaving Indigo Touch or an Indigo web browser page running continuously while not viewing it. By closing the browser window or leaving Indigo Touch (home button), the requests through the reflector will stop which significantly reduces daily bandwidth usage. | ||
| + | Note these usage suggestions only apply to connections when a reflector is being used. If you are directly connected to your Indigo Server on your home network or not using a reflector then the bandwidth isn't going through our servers and you can have Control Page images refreshed as frequently as you would like. | ||
