| indigo_2022.1_documentation:documents [2022/03/19 23:15] – [Technical Documents] - minor formatting. davel17 | indigo_2022.1_documentation:documents [2025/04/14 20:10] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Indigo 2022.1 Documentation ====== | ||
| + | Welcome to the Indigo 2022.1 Documentation pages. We've separated the docs into multiple areas, each focusing on some different part of Indigo 2022.1. | ||
| + | ===== Indigo User Documents ===== | ||
| + | This section contains links to documents that apply to the base Indigo product. It's the starting point if you're new to Indigo. We highly recommend starting with the [[Getting Started]] guide then progressing on to the other documents. | ||
| + | - [[Getting Started]] <- <color green> | ||
| + | - [[overview|Concept Overview]] - What are Devices, Triggers, Schedules, Action Groups, Control Pages, and Variables? | ||
| + | - [[ui_tour|Tour the Indigo Mac Client User Interface]] | ||
| + | - [[clients|Other Indigo Clients]] | ||
| + | - Indigo supports 3 interfaces, which can be active simultaneously ([[: | ||
| + | - If you have Z-Wave® devices, read through the [[Managing Z-Wave Devices|Managing Your Z-Wave Network]] document. Also, our [[:Z-Wave]] wiki article discusses, in general terms, what Z-Wave is and how it works. | ||
| + | - If you have INSTEON devices, read through the [[Managing INSTEON Devices|Managing Your INSTEON Network]] document. For some background on INSTEON links, we have put together a separate page that discusses [[: | ||
| + | - The [[Virtual Devices Interface]] provides several different devices that help you integrate Z-Wave, INSTEON, and 3rd party devices together and even create your own devices. | ||
| + | - The [[https:// | ||
| + | - [[getting_started# | ||
| + | ==== Other Help Pages ==== | ||
| + | There are other help documents available below and from the purple question mark icon {{: | ||
| + | * The [[ui_tour&# | ||
| + | * [[Deletion Dependencies]] | ||
| + | * [[Advanced PowerLinc Options]] | ||
| + | * [[X10 RF Interface Options]] | ||
| + | ===== Indigo Plugin Documents ===== | ||
| + | Indigo ships with many plugins to offer greater functionality. This section contains links to the documentation for each plugin that ships with Indigo. | ||
| + | * [[indigo_2022.1_documentation: | ||
| + | The [[indigo_2022.1_documentation: | ||
| + | ===== Indigo How-To Wiki ===== | ||
| + | Need step-by-step instructions on setting up specific home automation tasks? Or have a question about using a particular device/ | ||
| + | ===== Technical Documents ===== | ||
| + | We provide several powerful, yet easy to use ways to extend Indigo. We support a Python-based API that allows 3rd parties to integrate devices, events, and actions natively into Indigo without sacrificing speed and stability of the core server. This section provides links to all the documentation needed to develop scripts and plugins for Indigo. | ||
| + | **<color red> | ||
| + | **<color blue>A note about version numbers</ | ||
| + | If any of the API tables or functionality in the documentation don't have a version number you can assume that the feature is available in API version 1.0 and later. | ||
| + | * [[plugin_scripting_tutorial|Indigo 2022.1 Scripting Tutorial]] - dive into scripting Indigo by examples. | ||
| + | * [[plugin_extending_tutorial|Indigo 2022.1 Server Plugin Tutorial]] - examples of extending Indigo via plugins. | ||
| + | * The Indigo Plugin SDK ([[https:// | ||
| + | * [[plugin_guide|Indigo 2022.1 Plugin Developer' | ||
| + | * [[object_model_reference|Indigo 2022.1 Object Model Reference]] - the Indigo Object Model (IOM) and how to use it in Python. | ||
| + | * Want the ability to just put some Python scripts onto a menu somewhere for easy access? [[http:// | ||
| + | Check out the [[: | ||
| + | Want to add your plugin to the [[https:// | ||
| + | //Z-Wave® is a registered trademark of Sigma Designs, Inc. Indigo' | ||
