Link to this comparison view
indigo_2022.1_documentation:plugin_guide [2025/04/14 20:10] – external edit 127.0.0.1indigo_2022.1_documentation:plugin_guide [2025/10/23 23:09] (current) – [Custom HTML Config Dialogs] davel17
Line 707: Line 707:
 === Custom HTML Config Dialogs === === Custom HTML Config Dialogs ===
-You can also implement your own custom configuration in HTML if you prefer. Rather than adding lots of //''<Field>''// definitions, you simply specify a //''<URL>''// element. The URL specified can either be a fully specified URL (%%protocol://host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the [[indigo_2022.1_documentation:server_commands&#get_web_server_url|best base URL]]. You would then handle those form requests using [[#processing_http_requests_in_your_plugin|the built-in request handling mechanism discussed below]]. See the **Example HTTP Responder** plugin in the [[https://github.com/IndigoDomotics/IndigoSDK/releases/tag/v2022.1|SDK]] for an example.+You can also implement your own custom configuration in HTML if you prefer. Rather than adding lots of //''<Field>''// definitions, you simply specify a //''<URL>''// element. The URL specified can either be a fully specified URL <nowiki>(%%protocol://host/path%%)</nowiki> or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the [[indigo_2022.1_documentation:server_commands&#get_web_server_url|best base URL]]. You would then handle those form requests using [[#processing_http_requests_in_your_plugin|the built-in request handling mechanism discussed below]]. See the **Example HTTP Responder** plugin in the [[https://github.com/IndigoDomotics/IndigoSDK/releases/tag/v2022.1|SDK]] for an example.
 ==== Devices.xml ==== ==== Devices.xml ====
  • /www/perceptive/wiki/data/attic/indigo_2022.1_documentation/plugin_guide.1744661437.txt.gz
