Link to this comparison view
Next revision
Previous revision
indigo_2024.2_documentation:managing_z-wave_devices [2025/05/22 10:37] – [Resyncing and Replacing a Z-Wave Device] davel17indigo_2024.2_documentation:managing_z-wave_devices [2025/05/22 20:06] (current) – [Remove Failed Device from Controller] jay
Line 246: Line 246:
 Indigo can optimize your Z-Wave network by having devices rediscover which devices they are close enough to communicate with. This information is then reported back to the Z-Wave Controller so network routing tables can be updated. Indigo can optimize your Z-Wave network by having devices rediscover which devices they are close enough to communicate with. This information is then reported back to the Z-Wave Controller so network routing tables can be updated.
 +=== Report Failed Modules to Event Log ===
 +This menu item will write any devices that the Z-Wave interface believes may have failed to
 +the Indigo Events Log. This list is managed by the Z-Wave interface (not by Indigo) and it's
 +important to note that **the listed devices may not have actually failed** (the interface
 +may list a device that it hasn't received a transmission from for a while, for example). It's
 +recommended that you use this menu item from time to time to ensure that the interface has
 +the correct information for your devices.
 +<code>
 +January 1, 1970 at 12:34:56 AM
 +   Z-Wave                          found failed module reported by controller "028 - Energy Meter Device"
 +   Z-Wave                          found failed module reported by controller "042 - Dehumidifier"
 +</code>
 +If you see a device listed that you believe should not be listed, it is often enough to simply
 +browse to that device in the Indigo UI, open the Edit Device dialog, and perform a **Define
 +and Sync** operation. Indigo will attempt to refresh the device's information and, if successful, tell
 +the Z-Wave interface to remove the device from the failed devices list. After performing this
 +operation, you can confirm the device has been removed from the list by rerunning the
 +**Report Failed Modules to Event Log** step.
 +If the interface doesn't think that any devices are in a failed state, running the report will result in
 +<code>
 +   Z-Wave                          no failed modules found in controller
 +</code>
 === Remove Failed Device from Controller === === Remove Failed Device from Controller ===
-If a Z-Wave device is no longer available to your network (it failedetc.) then you can use this menu item to remove it from the interface. You might need to attempt a Define and Sync on the device (and allow it to fail) - just create a new device, try to sync it, when it fails then try to remove it.+If a Z-Wave device has failed or is no longer available to your network, you can use this menu item to remove it from the Z-Wave interface.
 +You may have to attempt to resync the device in order for it to be listed as failed.
 +  * If an Indigo device object still exists, you can open the Edit Device dialog and attempt to **Defne and Sync** the device. If it has truly failed, the sync operation will fail, and the interface will add it to its internal failed list.
 +  * If an Indigo device object is no longer available, you can simply create a new device, attempt to sync the failed device and, when the operation has failed, and the interface will add it to its internal failed list.
 +If you select this menu item and the Z-Wave interface doesn't have any failed devices in its list, Indigo will return this message:
 +<code>
 +</code>
 === Reset Z-Wave Interface === === Reset Z-Wave Interface ===
-You can completely reset your Z-Wave interface by selecting this menu item. You should only do this if instructed by Support.+You can completely reset your Z-Wave interface by selecting this menu item. **You should only do this if instructed by Support**.
 //Z-Wave® is a registered trademark of Sigma Designs, Inc. Indigo's support of Z-Wave hardware is neither endorsed nor certified by Sigma Designs.// //Z-Wave® is a registered trademark of Sigma Designs, Inc. Indigo's support of Z-Wave hardware is neither endorsed nor certified by Sigma Designs.//
  • /www/perceptive/wiki/data/attic/indigo_2024.2_documentation/managing_z-wave_devices.1747910260.txt.gz
  • Last modified: 2025/05/22 10:37
  • by davel17
