Link to this comparison view
indigo_5_documentation:insteon_specific_commands [2011/10/20 22:19] – created jayindigo_5_documentation:insteon_specific_commands [2025/02/18 20:36] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== INSTEON Commands (indigo.insteon.*) ======
 +Commands that are specific to INSTEON devices.
 +==== Send Scene ON ====
 +This command will send an INSTEON Scene ON command to the specified PowerLinc scene.
 +^  Command Syntax Examples  ^
 +|<code>indigo.insteon.sendSceneOn(11)</code>|
 +|<code>indigo.insteon.sendSceneOn(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneOn(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneOn(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneOn("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneOn("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +^  Parameter  ^  Required  ^  Type  ^  Description  ^
 +|direct parameter|  Yes  |  integer or string  |either the scene number or the scene name - we encourage numbers since they won't change and the scene names can.|
 +|//''sendCleanUps''// No  |  boolean  |a boolean indicating if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)|
 +|//''suppressLogging''// No  |  boolean  |a boolean indicating if entries in the event log should be suppressed (default is False)|
 +|//''updateStatesOnly''// No  |  boolean  |use if you only want Indigo's internal device state representation to be updated - no actual INSTEON command will be sent on RF or the power line (default is False)|
 +==== Send Scene OFF ====
 +This command will send an INSTEON Scene OFF command to the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneOff(11)</code>|
 +|<code>indigo.insteon.sendSceneOff(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneOff(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneOff(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneOff("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneOff("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +==== Send Scene Fast ON ====
 +This command will send an INSTEON Scene Fast ON command to the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneFastOn(11)</code>|
 +|<code>indigo.insteon.sendSceneFastOn(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneFastOn(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOn(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOn("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneFastOn("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
 +==== Send Scene Fast OFF ====
 +This command will send an INSTEON Scene Fast OFF command to the specified PowerLinc scene.
 +|<code>indigo.insteon.sendSceneFastOff(11)</code>|
 +|<code>indigo.insteon.sendSceneFastOff(11, sendCleanUps=False)</code>|
 +|<code>indigo.insteon.sendSceneFastOff(11, suppressLogging=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOff(11, updateStatesOnly=True)</code>|
 +|<code>indigo.insteon.sendSceneFastOff("working in office scene")</code>|
 +|<code>indigo.insteon.sendSceneFastOff("working in office scene", sendCleanUps=False)</code>|
 +^  Parameters  ^^^^
