This command will send an INSTEON Scene ON command to the specified PowerLinc scene.
sendCleanUps No boolean a boolean indicating if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might effect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)
suppressLogging No boolean a boolean indicating if entries in the event log should be suppressed (default is False)
This command will send an INSTEON Scene OFF command to the specified PowerLinc scene.
This command will send an INSTEON Scene Fast ON command to the specified PowerLinc scene.
This command will send an INSTEON Scene Fast OFF command to the specified PowerLinc scene.
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/insteon_specific_commands.txt
