| indigo_5_documentation:variable_class [2012/01/05 21:55] – [Class Properties] jay | indigo_5_documentation:variable_class [2025/02/18 20:36] (current) – external edit 127.0.0.1 |
| | ====== Variables ====== |
| | The variable class represents an Indigo variable. |
| | ==== Class Properties ==== |
| | ^Property ^ Type ^Description ^ |
| | |//''id''//| integer |the unique id of the variable, assigned on creation by IndigoServer| |
| | |//''folderId''//| integer |the unique id of the folder this variable is in (0 if it's not in a folder) - use //''moveToFolder()''// method to change| |
| | |//''name''//| string |the name of the variable - no two variable can have the same name| |
| | |//''readOnly''//| string |is the variable read only - currently only the //''isDaylight''// variable is read only| |
| | |//''remoteDisplay''//| boolean |should this variable be displayed in remote clients (IWS, Indigo Touch, etc)| |
| | |//''value''//| string |the value of the variable| |
| | ==== Class Method ==== |
| | The Variable class has a special method, ''**getValue(TYPE, default=VALUE)**'', that you can call which will retrieve the variable value as the specified Python class. There are a couple of advantages to using this method: first, it won't throw an exception but will always return a value; second, the Indigo server will do the conversion in the exact same way that it does type conversions when using variables in triggers and conditions. You can also optionally specify a default value if the value can't be successfully converted into the specified type. Here's a list of the valid types you can specify and what the default is if not specified: |
| | ^ Type Literal ^ Type Returned ^Default ^ |
| | | bool | Boolean |**''True''** will be returned if the value is one of these: "true", "on", "yes", and "1". ''**False**'' will be returned if the value is one of these: "false", "off", "no", and "0". If no default value is specified and the value can't be successfully converted, the method will return False. | |
| | | int | Integer |An integer object will be returned if the value is an integer number or a float/decimal. In the latter case, the number will be rounded to the nearest integer. If no default value is specified and the value can't be converted, the method will return 0 | |
| | | float | Float |A float object will be returned if the value is a float/decimal or an integer. If no default value is specified and the value can't be converted, the method will return 0.0 | |
| | Remember that accessing the ''**value**'' property of a variable object (''//var.value//'') will return a string object so you don't need a conversion for that. |
| | === Class Method Examples === |
| | <code># Get a variable |
| | var = indigo.variables[123456] |
| | # Getting the boolean value |
| | intValue = var.getValue(bool) # False if it can't be converted |
| | intValue = var.getValue(int, default=True) # True if it can't be converted |
| | # Getting the integer value |
| | intValue = var.getValue(int) # 0 if it can't be converted |
| | intValue = var.getValue(int, default=10) # 10 if it can't be converted |
| | # Getting the float value |
| | intValue = var.getValue(float) # 0 if it can't be converted |
| | intValue = var.getValue(float, default=98.6) # 98.6 if it can't be converted |
| | </code> |
| | ==== Commands (indigo.variable.*) ==== |
| | === Create === |
| | Create a variable. This method returns a **copy** of the newly created variable. |
| | ^ Command Syntax Examples ^ |
| | |<code>indigo.variable.create("VariableName", value="Var Value", folder=843920)</code>| |
| | ^ Parameters ^^^^ |
| | ^ Parameter ^ Required ^ Type ^ Description ^ |
| | |//''folder''//| No | integer |id or instance of the folder in which to put the newly created device - defaults to 0 (no folder)| |
| | |//''name''//| Yes | string |the name of the variable| |
| | |//''value''//| No | string |the value of the variable| |
| | === Delete === |
| | Delete the specified folder. |
| | |<code>indigo.variable.delete(123)</code>| |
| | ^ Parameters ^^^^ |
| | |direct parameter| Yes | integer |id or instance of the variable to delete| |
| | === Duplicate === |
| | Duplicate the specified variable. This method returns a copy of the new variable. |
| | |<code>indigo.variable.duplicate(123, duplicateName="NewName")</code>| |
| | ^ Parameters ^^^^ |
| | |direct parameter| Yes | integer |id or instance of the variable to duplicate| |
| | |//''duplicateName''//| No | string |name for the newly duplicated variable| |
| | === Move To Folder === |
| | Use this command to move the variable to a different folder. |
| | |<code>indigo.variable.moveToFolder(123, value=987)</code>| |
| | ^ Parameters ^^^^ |
| | |direct parameter| Yes | integer |id or instance of the variable| |
| | |//''value''//| Yes | integer |id or instance of the folder to move the variable to| |
| | === Set Remote Display === |
| | Use this command to set the remote display flag for the folder. |
| | |<code>indigo.variable.displayInRemoteUI(123, value=True)</code>| |
| | ^ Parameters ^^^^ |
| | |//''value''//| Yes | boolean |True to display the variable on remote user interfaces or False to hide it| |
| | === Update Value === |
| | Use this command to set the value of a variable without having to get a local copy first. |
| | |<code>indigo.variable.updateValue(123, value="New Value")</code>| |
| | ^ Parameters ^^^^ |
| | |//''value''//| Yes | string |the new value for the variable| |
| | ==== Examples ==== |
| | ^ Python ^ AppleScript ^ |
| | |<code># Create a new variable |
| | newVar = indigo.variable.create("fooName", "fooMonster") |
| | # Updating value via command space function: |
| | indigo.variable.updateValue(newVar, "asleep789") |
| | newVar.refreshFromServer() # refresh needed to update local's .value |
| | # changing name property |
| | newVar.name = "goodName" |
| | newVar.replaceOnServer() |
| | newVar.name = "bad name" # should throw because of space character |
| | # changing name and values properties: |
| | newVar.name = "goodName2" |
| | newVar.value = "searchingForWaldo" |
| | indigo.variable.delete(newVar) |
| | # Getting a variable using it's ID |
| | someVar = indigo.variables[123] |
| | # Getting a variable using it's name |
| | someVar = indigo.variables["MyVarName"]</code>|<code>-- Create a new variable |
| | set newVar to make new variable with properties {name:"fooName", value:"fooMonster"} |
| | -- Update value |
| | set value of newVar to "asleep789" |
| | -- Changing name property |
| | set name of newVar to "goodName" |
| | set newVar to variable "goodName" -- when the name changes, you have to get a fresh reference |
| | set name of newVar to "bad name" -- should error because of space character |
| | -- Changing name and values properties |
| | set name of newVar to "goodName2" |
| | set newVar to variable "goodName2" -- when the name changes, you have to get a fresh reference |
| | set value of newVar to "searchingForWaldo" |
| | delete variable "goodName2" |
| | # You can't get a variable using its ID in AppleScript |
| | set someVar to variable named "MyVarName"</code>| |
