| Next revision | Previous revision | ||
| inst_controller [2008/12/23 18:19] – created jay | inst_controller [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Insteon Controllers ====== | ||
| + | Insteon devices tend to fall into two categories: controllers and responders. Controllers are devices that send Insteon commands to other Insteon devices. The ControlLinc is a device which has 5 button pairs (along with all on/off and dim/ | ||
| + | Responders are Insteon devices that respond to commands. So, an ApplianceLinc or LampLinc will respond to commands sent to them: ON/OFF, Status Requests (to get state if Indigo gets out of sync somehow), and, in the case of the LampLinc, DIM/ | ||
| + | Many Insteon devices are both controllers and responders: KeypadLincs (which have 6 or 8 buttons), SwitchLincs, | ||
| + | Once you have your device defined, you'll probably want to do one of these things: | ||
| + | * [[scenes|Make a button to turn on/off a light]] - simple version without using Insteon Links - compatible with X10 devices as well | ||
| + | * [[inst_button_basics|Make a button to control an Insteon lighting scene]] - slightly more involved version for INSTEON only scenes, but performs better | ||
