Link to this comparison view
Next revision
Previous revision
inst_controller [2009/02/11 22:48] jayinst_controller [2026/04/07 18:27] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== Insteon Controllers ======
 +Insteon devices tend to fall into two categories: controllers and responders. Controllers are devices that send Insteon commands to other Insteon devices. The ControlLinc is a device which has 5 button pairs (along with all on/off and dim/brighten). You can set these buttons to perform many different actions.
 +Responders are Insteon devices that respond to commands. So, an ApplianceLinc or LampLinc will respond to commands sent to them: ON/OFF, Status Requests (to get state if Indigo gets out of sync somehow), and, in the case of the LampLinc, DIM/BRIGHTEN.
 +Many Insteon devices are both controllers and responders: KeypadLincs (which have 6 or 8 buttons), SwitchLincs, ToggleLincs, etc. They can be set up to send commands (via Links) and they can respond to commands from other devices.
 +Once you have your device defined, you'll probably want to do one of these things:
 +  * [[scenes|Make a button to turn on/off a light]] - simple version without using Insteon Links - compatible with X10 devices as well
 +  * [[inst_button_basics|Make a button to control an Insteon lighting scene]] - slightly more involved version for INSTEON only scenes, but performs better
