| Next revision | Previous revision | ||
| inst_remote_device_links [2009/02/11 18:06] – created jay | inst_remote_device_links [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ===== Remotely Managing Insteon Links and Scenes (Groups) ===== | ||
| + | The Insteon specification allows devices to be linked together for various purposes. Generally, you want to link a responder (for instance, a light switch) to a controller (for instance, a RemoteLinc remote control), so that when a button is pressed on a controller, the light responds to the command. This linking may be done manually by following the directions that come with the devices or they may be managed in Indigo. We're going to focus on the latter. | ||
| + | Scenes (or Groups - in Insteon terminology, | ||
| + | Indigo can remotely create and edit scenes (also called groups) between multiple remote modules. For example, you can use Indigo to remotely program button #1 on a RemoteLinc to: set the thermostat to 68°, turn off the bathroom light, brighten the bedroom sconces to 75%, dim the bedroom overhead fixture down to 35%, and turn off the hallway light. | ||
| + | Indigo automatically creates the links to define the scene in most remote modules. This means you do not have to press-and-hold the set button or up paddle on most remote modules. Indigo will do it all remotely for you with a single press of the **Sync Now** button. See the **Remote Insteon Linking** option on the detail page for any supported Insteon device linked from our [[http:// | ||
| + | You can also define Indigo initiated scenes to control multiple remote modules in unison. See [[inst_indigo_scenes|defining Indigo Insteon scenes]] for more information on this capability. | ||
| + | This [[wiki: | ||
| + | ==== Defining the Scene between Modules ==== | ||
| + | First, select the module you want to edit. You can choose to edit either the controller module in the scene (ex: RemoteLinc) or the responder module in the scene (ex: LampLinc). | ||
| + | - Choose '' | ||
| + | - Select the module' | ||
| + | If the module you selected is a controller (RemoteLinc, | ||
| + | - If you want to add a new responder module to the scene, then press the '' | ||
| + | - Choose the button or group number that identifies the scene you are defining in the controller (ex: RemoteLinc button #1) from the '' | ||
| + | - Choose the responder module' | ||
| + | - When responding to a scene command, most modules will control the main load (light or appliance) connected to that module. For these modules (SwitchLinc, | ||
| + | - Optionally turn on the '' | ||
| + | - Repeat steps 1 through 5 for every new responder module that you want to add to the selected controller. | ||
| + | If the module you selected is a responder (LampLinc, Thermostat Adapter, KeypadLinc, SwitchLinc, etc.), then you can add or edit controllers: | ||
| + | - If you want to add a controller of the selected responder module, then press the '' | ||
| + | - Choose the controller module' | ||
| + | - Choose the button or group number that identifies the controller scene for which you want the responder to listen (ex: RemoteLinc button #3) from the '' | ||
| + | - Repeat steps 1 through 5 for every new controller module you want to add for the selected responder. | ||
| + | Last, have Indigo write all of your link changes to the remote modules: | ||
| + | * Press the Sync Now button to have Indigo immediately write all changed links to the remote modules. | ||
| + | **OR** | ||
| + | * Press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync Insteon Device Links... from the Interface menu, and then press the Sync Changes Only button. | ||
