his article is about the two APIs in IWS that developers can use to integrate Indigo with external services:
NOTE:
/v2/
- this is the top level version number and will change as necessaryIn these APIs, we’re using JSON (JavaScript Object Notation) as the message format for communicating between the WebSocket and HTTP APIs and IWS. In JavaScript, an “object” definition looks (almost) exactly like a Python dictionary (and vice versa). So we may refer to an object or dictionary (dict): for the purposes of this document, they refer to the same JSON construct. For example, we may call this an object or a dict:
{ "key1": "value 1", "key2": 2 }
Python developers will notice the use of null
in the message descriptions. This corresponds to the Python None
object. Also of note are the booleans true
and false
, which are capitalized in Python but not in JSON. Here’s a handy cheat sheet:
Python | JSON Equivalent |
True | true |
False | false |
float | Number |
int | Number |
None | null |
dict | Object |
list | Array |
tuple | Array |
str | String |
/v2/api/ws/device-feed
- WebSocket to do all communication about devices/v2/api/ws/variable-feed
- WebSocket to do all communication about variables/v2/api/ws/action-feed
- WebSocket to do all communication about action groups/v2/api/ws/page-feed
- WebSocket to do all communication about control pages/v2/api/ws/log-feed
- WebSocket to do all communication about logsEach feed (except log feed) sends the following server messages:
Note the protocol: wss
. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Don't share your API keys with anyone who isnot authorized to use them — especially in posts to the Indigo user forums.
Here's a simple Python script to open the device-feed and print out any messages it receives (you'll need to pip3 install websockets
before running it).
import asyncio import json from websockets import connect API_KEY = 'YOUR_API_KEY' # YOUR API KEY HERE DEVICE_ID = 12345678 # YOUR DEVICE ID HERE HEADERS = {"Authorization": f"Bearer {API_KEY}"} URI = "ws://127.0.0.1:8176/v2/api/ws/device-feed" # wss:// if using the reflector async def receiver(ws): try: print("Starting receiver task") # Ask for a refresh of device with ID 12345678 refresh_message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } await ws.send(json.dumps(refresh_message)) counter = 0 device = {} while counter < 20: # just keep looping waiting for a message to come log_string = "ignoring message" message_json = await ws.recv() message = json.loads(message_json) message_type = message['message'] if message_type == "refresh": # This is the response to the refresh message we sent above. It gets us a full copy of the device. device = message["objectDict"] log_string = f"receiver: device refresh message: '{device.get('name', 'unknown')}'" elif message_type == "patch": # There's been a change, so confirm it's the device we want then log the change if message["objectId"] == device["id"]: log_string = f"'receiver: device patch message: {device.get('name', 'unknown')}' update: \n{message_json}" print(f"receiver: loop count: {counter}") print(f"receiver: {log_string}") counter += 1 except Exception as exc: print(f"Exception:\n{exc}") async def sender(ws, count): try: print("Starting sender task") message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } for count in range(10): print(f"sender: loop count: {count}") msg = json.dumps(message) print(f"sender: sending message: {msg}") await ws.send(json.dumps(msg)) await asyncio.sleep(5) except Exception as exc: print(f"Exception:\n{exc}") async def main(): try: async with connect(URI, extra_headers=HEADERS) as websocket: await asyncio.gather(receiver(websocket), sender(websocket, 10)) except Exception as exc: print(f"Exception:\n{exc}") asyncio.run(main())
Here's a simple nodejs JavaScript to open the device-feed and print out any messages it receives (you'll need to npm install websocket
before running it).
{ "message": "add", "objectType": "indigo.Device", objectDict": { "class": "indigo.DimmerDevice", "address": "3B.04.7A", "batteryLevel": null, "blueLevel": null, "brightness": 100, "buttonConfiguredCount": 0, "buttonGroupCount": 1, "configured": true, "defaultBrightness": 100, "description": "- sample device -", "deviceTypeId": "", "displayStateId": "brightnessLevel", "displayStateImageSel": "indigo.kStateImageSel.DimmerOn", "displayStateValRaw": 100, "displayStateValUi": "100", "enabled": true, "energyAccumBaseTime": null, "energyAccumTimeDelta": null, "energyAccumTotal": null, "energyCurLevel": null, "errorState": "", "folderId": 1552926800, "globalProps": { "com.indigodomo.indigoserver": {}, "emptyDict": {} }, "greenLevel": null, "id": 1508839119, "lastChanged": "2023-02-16T15:43:53", "lastSuccessfulComm": "2023-02-16T15:43:53", "ledStates": [], "model": "LampLinc (dual-band)", "name": "Insteon Dimmer", "onBrightensToDefaultToggle": true, "onBrightensToLast": false, "onState": true, "ownerProps": {}, "pluginId": "", "pluginProps": {}, "protocol": "indigo.kProtocol.Insteon", "redLevel": null, "remoteDisplay": false, "sharedProps": {}, "states": { "brightnessLevel": 100, "onOffState": true }, "subModel": "Plug-In", "subType": "Plug-In", "supportsAllLightsOnOff": true, "supportsAllOff": true, "supportsColor": false, "supportsOnState": true, "supportsRGB": false, "supportsRGBandWhiteSimultaneously": false, "supportsStatusRequest": true, "supportsTwoWhiteLevels": false, "supportsTwoWhiteLevelsSimultaneously": false, "supportsWhite": false, "supportsWhiteTemperature": false, "version": 67, "whiteLevel": null, "whiteLevel2": null, "whiteTemperature": null } }
{ "message": "patch", "objectType": "indigo.Device", "objectId": 1508839119, "patch": [ [ "change", "brightness", [100, 0] ], [ "change", "displayStateImageSel", ["indigo.kStateImageSel.DimmerOn", "indigo.kStateImageSel.DimmerOff"] ], [ "change", "displayStateValRaw", [100, 0] ], [ "change", "displayStateValUi", ["100", "0"] ], [ "change", "lastChanged", ["2023-02-17T16:29:56", "2023-02-17T16:30:54"] ], [ "change", "lastSuccessfulComm", ["2023-02-17T16:29:56", "2023-02-17T16:30:54"] ], [ "change", "onState", [true, false] ], [ "change", "states.brightnessLevel", [100, 0] ], [ "change", "states.onOffState", [true, false] ] ] }
Patch objects are created via the dictdiffer python module, by comparing the device dictionary (dict(some_device)
) for the old device with the one for the new dictionary as they are received in the device_updated()
plugin method call. We've implemented a JavaScript library, dictdiffer-js, to patch JavaScript objects given the patch object created by the dictdiffer Python library. You can use it in your projects if you like.
{ "id": "optional-custom-user-message", "message": "refresh", "objectType": "indigo.Device", "list": [] }
{ "id": "optional-custom-user-message", "message": "refresh", "objectType": "indigo.Device", "objectDict": {} }
{ "message": "delete", "objectType": "indigo.Device", "objectId": 123456789 }
{ "id": "optional-custom-user-message", "message": "refresh", // Specify the object type "objectType": "indigo.Device", "objectId": 123456789 }
If you want the entire device list, simply omit the objectId
key and the server will return the full list. The server will respond with the appropriate device refresh message shown above.
{ "id": "optional-custom-user-message", "message": "indigo.device.toggle", "objectId": 123456789, }
{ "class": "indigo.Variable", "description": "", "folderId": 0, "globalProps": { "com.indigodomo.indigoserver": {} }, "id": 345633244, "name": "house_status", "pluginProps": {}, "readOnly": false, "remoteDisplay": true, "sharedProps": {}, "value": "home" }
{ "message": "add", "objectType": "indigo.Variable", "objectDict": {} // Variable object as outlined above }
{ "message": "patch", // we use a patch rather than send the entire updated device "objectType": "indigo.Variable", "patch": {} // A patch object - see the Object Patches below for details }
Variable patch objects are created via the dictdiffer python module by comparing the variable dictionary (dict(some_variable)
) for the old variable with the one for the new dictionary as they are received in the variable_updated()
Plugin method call.
{ "message": "delete", "objectType": "indigo.Variable", "objectId": 123456789 }
{ "id": "optional-custom-user-message", "message": "refresh", "objectType": "indigo.Variable", "objectDict": {} // Variable object as outlined above }
{ "id": "optional-custom-user-message", "message": "refresh", "objectType": "indigo.Variable", "list": [] // a list of Variable objects as outlined above }
The updateValue
command is currently the only command message you can send to the variable feed. It closely mirrors the Python-based IOM command for updating variables. This was completely intentional to make learning one API a stepping stone to another. The HTTP API messages and the Websocket API messages are identical, and are very clearly a JSON-rendered version of the associated IOM command.
{ // Note, values passed in the parameter dictionary must be strings. You can // pass in an empty string ("") to clear the variable value. "id": "optional-custom-user-message", "message": "indigo.variable.updateValue", "objectId": 123456789, // the variable id to update "parameters": { "value": "Some string value" } }
{ "class": "indigo.ActionGroup", "description": "", "folderId": 532526508, "globalProps": { "com.indigodomo.indigoserver": { "speakDelayTime": "5", "speakTextVariable": "speech_string" } }, "id": 94914463, "name": "Movie Night", "pluginProps": {}, "remoteDisplay": true, "sharedProps": { "speakDelayTime": "5", "speakTextVariable": "speech_string" } }
{ "message": "add", "objectType": "indigo.ActionGroup", "objectDict": {} // ActionGroup object as outlined above }
{ "message": "patch", // we use a patch rather than send the entire updated device "objectType": "indigo.ActionGroup", "patch": {} // A patch object - see the Object Patches below for details }
Action group patch objects are created via the dictdiffer python module, by comparing the action dictionary (dict(some_action_group)
) for the old action with the one for the new dictionary as they are received in the action_group_updated()
Plugin method call.
{ "message": "delete", "objectType": "indigo.ActionGroup", "objectId": 123456789 }
{ "id": "optional-custom-user-message", "message": "refresh", "objectType": "indigo.ActionGroup", "objectDict": {} // ActionGroup object as outlined above }
{ "id": "optional-custom-user-message", "message": "refresh", "objectType": "indigo.ActionGroup", "list": [] // a list of ActionGroup objects as outlined above }
The execute
command is currently the only command message you can send to the action group feed. It closely mirrors the Python-based IOM command for executing action groups. This was completely intentional to make learning one API a stepping stone to another. The HTTP API messages and the Websocket API messages are identical, and are very clearly a JSON-rendered version of the associated IOM command.
{ "id": "optional-custom-user-message", "message": "indigo.actionGroup.execute", "objectId": 123456789 // the action group id to execute }
{ "class": "indigo.ControlPage", "backgroundImage": "", "description": "", "folderId": 0, "globalProps": {}, "hideTabBar": true, "id": 963336187, "name": "Weather Images", "pluginProps": {}, "remoteDisplay": true, "sharedProps": {} }
{ "message": "add", "objectType": "indigo.ControlPage", "objectDict": {} // ControlPage object as outlined above }
{ "message": "patch", // we use a patch rather than send the entire updated control page "objectType": "indigo.ControlPage", "patch": {} // A patch object - see the Object Patches below for details }
Page patch objects are created via the dictdiffer python module, by comparing the device dictionary (dict(some_page)
) for the old page with the one for the new dictionary as they are received in the control_page_updated()
Plugin method call.
{ "message": "delete", "objectType": "indigo.ControlPage", "objectId": 123456789 }
{ "id": 617272302, "class": "indigo.Folder", "name": "My Device Folder", "remoteDisplay": true }
{ "message": "refresh", "id": "optional-custom-user-message", "objectType": "indigo.Device.Folder", }
{ "message": "refresh", "id": "optional-custom-user-message", "objectType": "indigo.Device.Folder", // or indigo.Variable.Folder, etc "list": [] // A list of folder objects defined above }
{ "message": "add", "objectType": "indigo.LogEvent", "objectDict": { "message": "Stopping plugin \"Web Server 2023.1.0\" (pid 1020)", "timeStamp": "2022-12-01T12:03:27.759000", "typeStr": "Application", "typeVal": 0 "objectType": "indigo.LogEvent" } }
/v2/api/indigo.devices
- endpoint to get a list of devices/v2/api/indigo.devices/123456789
- endpoint to get a specific device instance (See Device Objects below)/v2/api/indigo.variables
- endpoint to get a list of variables/v2/api/indigo.variables/123456789
- endpoint to specific variable object (See Variable Objects below)/v2/api/indigo.actionGroups
- endpoint to get a list of action groups/v2/api/indigo.actionGroups/123456789
- endpoint to get a specific action group (See Action Group Objects below)/v2/api/command
- endpoint to send Indigo a command (device control, variable update, action execution).You’ll receive full JSON objects which represent either a list of all instances of the object type requested (for example, a list of all action groups) or an individual Indigo object instance (a single device, variable, etc.) Each individual object will be different based on the object type, class and its definition (a custom device, for example). See the Indigo Object Model docs for details about each object type.
YOUR-API-KEY
with a valid key from your Indigo account.YOUR-REFLECTOR-NAME
with the reflector name for your Indigo server.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/indigo.devices") req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: device_list = json.load(request) print(device_list)
YOUR-API-KEY
with the reflector name for your Indigo server.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" // Get the http module, and tell it that you're using HTTPS const http = require("https") // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.devices`, headers: { Authorization: `Bearer ${APIKEY}` } } // Get the device JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const deviceList = JSON.parse(result); console.log(deviceList); }) })
YOUR-API-KEY
with the reflector name for your Indigo server.curl -H "Authorization: Bearer YOUR-API-KEY" https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices
YOUR-API-KEY
with the reflector name for your Indigo server.123456789
with a valid Indigo device ID.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" DEVICEID = 123456789 req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/indigo.devices/{DEVICEID}") req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: device_instance = json.load(request) print(device_instance)
YOUR-API-KEY
with a valid Indigo device ID.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const DEVICEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.devices/${DEVICEID}`, headers: { Authorization: `Bearer ${APIKEY}` } } // Get the device JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) })
YOUR-API-KEY
with the reflector name for your Indigo server.curl -H "Authorization: Bearer YOUR-API-KEY" https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices/123456789
YOUR-API-KEY
with a valid Indigo device ID.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" DEVICEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-custom-user-message", "message": "indigo.device.toggle", "objectId": DEVICEID }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
YOUR-API-KEY
with a valid Indigo device ID.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const DEVICEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-custom-user-message", "message": "indigo.device.toggle", "objectId": DEVICEID }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the device JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) req.write(message) req.end()
YOUR-API-KEY
with a valid Indigo device ID.curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.device.toggle", "objectId": 123456789}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
As noted above, Indigo devices come in a variety of types, and each type has its own command set. As a part of this command set, some devices require specific parameters in order for Indigo to be able to execute them (some devices accept optional parameters, and others do not require any parameters at all). See the Device Command Messages below for a description of all messages. The following examples use the indigo.dimmer.setBrightness
command and demonstrate how to include parameters.
YOUR-API-KEY
with a valid Indigo device ID.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" DEVICEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-custom-user-message", "message": "indigo.dimmer.setBrightness", "objectId": DEVICEID, "parameters": { "value": 50, "delay": 10 } }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
YOUR-API-KEY
with a valid Indigo device ID.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const DEVICEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-custom-user-message", "message": "indigo.dimmer.setBrightness", "objectId": DEVICEID, "parameters": { "value": 50, "delay": 10 } }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the device JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) req.write(message) req.end()
YOUR-API-KEY
with a valid Indigo device ID.curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.dimmer.setBrightness", "objectId": 123456789, "parameters": {"value": 50, "delay": 10}}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
YOUR-API-KEY
with the reflector name for your Indigo server.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/indigo.variables") req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: variable_list = json.load(request) print(variable_list)
YOUR-API-KEY
with the reflector name for your Indigo server.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" // Get the http module, and tell it that you're using HTTPS const http = require("https") // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.variables`, headers: { Authorization: `Bearer ${APIKEY}` } } // Get the variable JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const VariableList = JSON.parse(result); console.log(VariableList); }) })
YOUR-API-KEY
with the reflector name for your Indigo server.curl -H "Authorization: Bearer YOUR-API-KEY" https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables
YOUR-API-KEY
with a valid Indigo variable ID.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" VARID = 123456789 # Indigo variable object id req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/indigo.variables/{VARID}") req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: var_instance = json.load(request) print(var_instance)
YOUR-API-KEY
with a valid Indigo variable ID.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const VARID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.variables/${VARID}`, headers: { Authorization: `Bearer ${APIKEY}` } } // Get the variable object JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const varInstance = JSON.parse(result); console.log(varInstance); }) })
YOUR-API-KEY
with a valid Indigo variable ID.curl -H "Authorization: Bearer YOUR-API-KEY" https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables/123456789
YOUR-API-KEY
with a valid Indigo variable ID.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" VARIABLEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-custom-user-message", "message": "indigo.variable.updateValue", "objectId": VARIABLEID, "parameters": { "value": "Some string value" } }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
YOUR-API-KEY
with a valid Indigo variable ID.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const VARIABLEID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-custom-user-message", "message": "indigo.variable.updateValue", "objectId": VARIABLEID, "parameters": { "value": "Some string value" } }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the variable JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const VariableInstance = JSON.parse(result); console.log(VariableInstance); }) }) req.write(message) req.end()
YOUR-API-KEY
with a valid Indigo variable ID.curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.variable.updateValue", "objectId": 123456789, "parameters": {"value": "Some string value"}}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
YOUR-API-KEY
with the reflector name for your Indigo server.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/indigo.actionGroups") req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: action_group_list = json.load(request) print(action_group_list)
YOUR-API-KEY
with the reflector name for your Indigo server.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" // Get the http module, and tell it that you're using HTTPS const http = require("https") // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.actionGroups`, headers: { Authorization: `Bearer ${APIKEY}` } } // Get the action group JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const actionGroupList = JSON.parse(result); console.log(actionGroupList); }) })
YOUR-API-KEY
with the reflector name for your Indigo server.curl -H "Authorization: Bearer YOUR-API-KEY" https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.actionGroups
YOUR-API-KEY
with a valid Indigo action group ID.# This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = "YOUR-REFLECTOR-NAME" APIKEY = "YOUR-API-KEY" ACTIONGROUPID = 123456789 # The message to send to the Indigo Server message = json.dumps({ "id": "optional-custom-user-message", "message": "indigo.actionGroup.execute", "objectId": ACTIONGROUPID }).encode("utf8") req = Request(f"https://{REFLECTORNAME}.indigodomo.net/v2/api/command", data=message) req.add_header('Authorization', f"Bearer {APIKEY}") with urlopen(req) as request: reply = json.load(request) print(reply)
YOUR-API-KEY
with a valid Indigo action group ID.// Things that are specific to your environment const REFLECTORNAME = "YOUR-REFLECTOR-NAME" const APIKEY = "YOUR-API-KEY" const ACTIONGROUPID = 123456789 // Get the http module, and tell it that you're using HTTPS const http = require("https") // The message to send to the Indigo Server const message = JSON.stringify({ "id": "optional-custom-user-message", "message": "indigo.actionGroup.execute", "objectId": ACTIONGROUPID }) // These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: "/v2/api/command", method: "POST", headers: { Authorization: `Bearer ${APIKEY}`, "Content-Length": message.length } } // Get the action group JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) => { let result = "" response.on("data", chunk => { result += chunk; }) response.on("end", () => { const actionGroupInstance = JSON.parse(result); console.log(actionGroupInstance); }) }) req.write(message) req.end()
YOUR-API-KEY
with a valid Indigo action group ID.curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.actionGroup.execute", "objectId": 123456789}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command
{ "class": "indigo.DimmerDevice", "address": "3B.04.7A", "batteryLevel": null, "blueLevel": null, "brightness": 0, "buttonConfiguredCount": 0, "buttonGroupCount": 1, "configured": true, "defaultBrightness": 100, "description": "- sample device -", "deviceTypeId": "", "displayStateId": "brightnessLevel", "displayStateImageSel": "indigo.kStateImageSel.DimmerOff", "displayStateValRaw": 0, "displayStateValUi": "0", "enabled": true, "energyAccumBaseTime": null, "energyAccumTimeDelta": null, "energyAccumTotal": null, "energyCurLevel": null, "errorState": "", "folderId": 1552926800, "folder": { "class": "indigo.Folder", "id": 1552926800, "name": "Insteon", "remoteDisplay": true }, "globalProps": {}, "greenLevel": null, "id": 1508839119, "lastChanged": "2023-02-01T11:39:58", "lastSuccessfulComm": "2023-02-01T11:39:58", "ledStates": [], "model": "LampLinc (dual-band)", "name": "Insteon Dimmer", "onBrightensToDefaultToggle": true, "onBrightensToLast": false, "onState": false, "ownerProps": {}, "pluginId": "", "pluginProps": {}, "protocol": "indigo.kProtocol.Insteon", "redLevel": null, "remoteDisplay": false, "sharedProps": {}, "states": { "brightnessLevel": 0, "onOffState": false }, "subModel": "Plug-In", "subType": "Plug-In", "supportsAllLightsOnOff": true, "supportsAllOff": true, "supportsColor": false, "supportsOnState": true, "supportsRGB": false, "supportsRGBandWhiteSimultaneously": false, "supportsStatusRequest": true, "supportsTwoWhiteLevels": false, "supportsTwoWhiteLevelsSimultaneously": false, "supportsWhite": false, "supportsWhiteTemperature": false, "version": 67, "whiteLevel": null, "whiteLevel2": null, "whiteTemperature": null }
HTTP The folder
element is only available in the HTTP API. Folders are handled differently in the WebSocket API.
The id
key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id
values should be strings.
{ "id": "optional-custom-user-message", "message": "indigo.device.statusRequest", "objectId": 123456789 }
WebSocket This won't necessarily cause a device update message - if the device didn't have any changes after the status request, there will be no updates to the device in the server, so no update message will be sent out the websocket.
{ "id": "optional-custom-user-message", "message": "indigo.device.toggle", "objectId": 123456789, "parameters": { "delay": 5, "duration": 10 } }
objectId
is the id of the device. The parameters
dictionary is optional.
{ "id": "optional-custom-user-message", "message": "indigo.device.turnOff", "objectId": 123456789, "parameters": { "delay": 5, "duration": 10 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.device.turnOn", "objectId": 123456789, "parameters": { "delay": 5, "duration": 10 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.device.lock", "objectId": 123456789, "parameters": { "delay": 5, "duration": 10 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.device.unlock", "objectId": 123456789, "parameters": { "delay": 5, "duration": 10 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.device.enable", "objectId": 123456789, "parameters": { "value": True, } }
objectId
is the id of the device. The value
parameter is optional (True
to enable, False
to disable).
{ "id": "optional-custom-user-message", "message": "indigo.dimmer.brighten", "objectId": 123456789, "parameters": { "by": 5, "delay": 10 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.dimmer.dim", "objectId": 123456789, "parameters": { "by": 5, "delay": 10 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.dimmer.setBrightness", "objectId": 123456789, "parameters": { "value": 50, "delay": 10 } }
objectId
parameter is required and the delay
parameter is optional.
{ "id": "optional-custom-user-message", "message": "indigo.iodevice.setBinaryOutput", "objectId": 123456789, "parameters": { "index": 5, "value": true } }
objectId
is the id of the device. The index
and value
parameters are required.
{ "id": "optional-custom-user-message", "message": "indigo.sensor.setOnState", "objectId": 123456789, "parameters": { "value": true } }
objectId
parameter is required.
{ "id": "optional-custom-user-message", "message": "indigo.speedcontrol.decreaseSpeedIndex", "objectId": 123456789, "parameters": { "by": 2, "delay": 5 } }
objectId
is the id of the device. The by
and delay
parameters are optional.
{ "id": "optional-custom-user-message", "message": "indigo.speedcontrol.increaseSpeedIndex", "objectId": 123456789, "parameters": { "by": 2, "delay": 5 } }
objectId
and delay
{ "id": "optional-custom-user-message", "message": "indigo.speedcontrol.setSpeedIndex", "objectId": 123456789, "parameters": { "value": 2, "delay": 5 } }
objectId
set speed level indigo.speedcontrol.setSpeedLevel(123456789, value=50, value=True)
{ "id": "optional-custom-user-message", "message": "indigo.speedcontrol.setSpeedLevel", "objectId": 123456789, "parameters": { "value": 50, "delay": 5 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.nextZone", "objectId": 123456789 }
objectId
is the id of the device. The next zone
command does not have any additional parameters.
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.pause", "objectId": 123456789 }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.previousZone", "objectId": 123456789 }
objectId
is the id of the device. The previous zone
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.resume", "objectId": 123456789 }
objectId
is the id of the device. The resume schedule
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.run", "objectId": 123456789, "parameters": { "schedule": [10,15,8, 0, 0, 0, 0, 0] } }
objectId
is the id of the device. The schedule
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.stop", "objectId": 123456789 }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.sprinkler.setActiveZone", "objectId": 123456789, "parameters": { "index": 2 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.decreaseCoolSetpoint", "objectId": 123456789, "parameters": { "delta": 2 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.decreaseHeatSetpoint", "objectId": 123456789, "parameters": { "delta": 2 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.increaseCoolSetpoint", "objectId": 123456789, "parameters": { "delta": 2 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.increaseHeatSetpoint", "objectId": 123456789, "parameters": { "delta": 2 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.setCoolSetpoint", "objectId": 123456789, "parameters": { "value": 76 } }
objectId
parameters is required.
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.setFanMode", "objectId": 123456789, "parameters": { "value": "indigo.kFanMode.AlwaysOn" } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.setHeatSetpoint", "objectId": 123456789, "parameters": { "value": 76 } }
objectId
{ "id": "optional-custom-user-message", "message": "indigo.thermostat.setHvacMode", "objectId": 123456789, "parameters": { "value": "indigo.kHvacMode.HeatCool" } }
objectId
{ "class": "indigo.Variable", "description": "", "folderId": 0, "folder": {}, "globalProps": { "com.indigodomo.indigoserver": {} }, "id": 345633244, "name": "house_status", "pluginProps": {}, "readOnly": false, "remoteDisplay": true, "sharedProps": {}, "value": "home" }
HTTP The folder
The only action that can currently be performed on a variable is to update the value. The id
{ "id": "optional-custom-user-message", "message": "indigo.variable.updateValue", "objectId": 123456789, "parameters": { "value": "Some string value" } }
objectId
is the id of the variable. The value
parameter is required and must be a string. Pass an empty string (“”) to clear the variable value.
{ "class": "indigo.ActionGroup", "description": "", "folderId": 532526508, "folder": { "class": "indigo.Folder", "id": 532526508, "name": "Mood Scenes", "remoteDisplay": true }, "globalProps": { "com.indigodomo.indigoserver": { "speakDelayTime": "5", "speakTextVariable": "speech_string" } }, "id": 94914463, "name": "Movie Night", "pluginProps": {}, "remoteDisplay": true, "sharedProps": { "speakDelayTime": "5", "speakTextVariable": "speech_string" } }
HTTP The folder
There is only a single action group command, and that's to execute it. The id
{ "id": "optional-custom-user-message", "message": "indigo.actionGroup.execute", "objectId": 123456789 }
objectId
is the id of the action group.
We convert the event Indigo dictionary into a python dictionary in the event_log_line_received
plugin method.
Note that typeVal
will be one of the following values:
{ "error": "Some error description", "id": "the id sent from the client in the message, or null if there wasn't one", "validationErrors": { "field1": "some error that occurred in the message with the key field1" } }
where the value of the JSON name (or key) validationErrors
is a dictionary with a field name and a description of the error in that field that came from the client. For instance, if you pass a float value
to the indigo.variable.updateValue
message:
{ "id": "a-random-id-for-this-message", "message": "indigo.variable.updateValue", "objectId": 123456789, "parameters": { "value": 1234.56 } }
{ "validationErrors": { "value": "variable values must be strings" }, "error": "invalid command payload received, id: my-set-var-command", "id": "a-random-id-for-this-message" }
The error
key is the indicator that the response is some kind of error. validationErrors
is a dict which contains all the validation errors for the message, in this case the value
that was passed in was not a string (it was the float 1234.56
). The possible keys in the error message reply validationErrors
could be:
message
,objectId
,parameters
, andvalue
based on the indigo.variable.updateValue
message format (we do no validation on the id
value passed in, we pass it through, and if your message doesn’t contain one then the value will be null
). Only the keys from your message that have errors will be returned. So in the example error above, only the value
key had a validation error (because we passed in a float) so that was the only key returned.
id
is the ID you (may have) passed in when you sent the command message.
{ "request_body": "this is not valid JSON", "error": "invalid JSON" }
Code | Condition | Description |
200 | OK or Success | Indicates that the request has succeeded. |
400 | Bad Request | Indicates that the server cannot or will not process the request due to something that is perceived to be a client error (for example, malformed request syntax, invalid request message framing, or deceptive request routing) |
401 | Unauthorized | Indicates that the client request has not been completed because it lacks valid authentication credentials for the requested resource. |
404 | Not Found | Indicates that the server cannot find the requested resource. |
500 | Internal Server Error | Indicates that the server encountered an unexpected condition that prevented it from fulfilling the request. |
