| zwave_devices:firstalert [2013/09/30 22:30] – [First Alert (aka BRK Brands, Inc.)] jay | zwave_devices:firstalert [2025/02/18 20:36] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== First Alert (aka BRK Brands, Inc.) ====== | ||
| + | ===== Smoke & Fire Alarm (ZSMOKE) ===== | ||
| + | To include this device: | ||
| + | - Put your Z-Wave interface into inclusion mode | ||
| + | - Slide out the battery compartment on the smoke alarm | ||
| + | - Press and hold the Test/ | ||
| + | - Release the button - your interface should show a successful inclusion | ||
| + | The device will stay awake for 30 seconds so if you're doing a resync you'll want to be pretty quick. Exclusion works the same way, just make sure you have your interface in exclusion mode in step 1 above. | ||
| + | When the alarm detects smoke/fire, the device state for the Indigo device will turn ON. When the alarm stops detecting smoke/fire the device state will go OFF. Pressing and holding the Test/ | ||
| + | We've enabled the Turn On/Off buttons in the control area so you can manually adjust the on/off state if it gets out of sync. It will not affect the actual operation of the alarm. | ||
| + | [[http:// | ||
| + | [[https:// | ||
| + | ===== Smoke/Fire & Carbon Monoxide Alarm (ZCOMBO) ===== | ||
| + | This device is basically identical to the ZSMOKE except it will also alarm on high Carbon Monoxide readings. Indigo won't know which caused the alarm to sound - it's just a single ON/OFF command. Inclusion information is the same as above. | ||
| + | [[http:// | ||
| + | [[https:// | ||
