| zwave_devices:gocontrol [2018/02/18 21:11] – [GoControl (aka Linear, Nortek)] jay | zwave_devices:gocontrol [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== GoControl (aka Linear, Nortek) ====== | ||
| + | [[https:// | ||
| + | ===== GoControl QuickStick Combo ===== | ||
| + | This is a combination Z-Wave and ZigBee interface in one USB stick. Indigo doesn' | ||
| + | To use this interface, you'll need to have the Silicon Labs VCP driver v5.0.4 or later installed on your Mac. Unlike other devices that use the SiLabs drivers, this device seems very well implemented. Once you have the driver installed and the stick is plugged in, you'll see two serial ports in the popup in the Z-Wave config dialog that are very clearly named for their purpose: | ||
| + | Just select the Z-Wave port and you'll be off and running. | ||
| + | [[http:// | ||
