API v2.4 Release Notes
This version of the API shipped with Indigo 7.5.0 - check the API Version Chart to see what version of the API is available in which Indigo versions.
  • Added new methods to get the plugin list indigo.server.getPluginList() and check if a plugin instance is installed plugin.isInstalled().
  • Added optional level argument to the indigo.server.log() method to specify the python logging level that will determine the Event Log window text color used. Possible values include: logging.INFO (black), logging.WARNING (orange), logging.ERROR (red). The default plugin instance logger will also now map self.logger.warn() to use an orange text color as well. Example usage:
import logging
  • /www/perceptive/wiki/data/pages/api_release_notes/2.4.txt
