Both sides previous revision Previous revision Next revision | Previous revision | ||
common_tasks_in_applescript [2009/03/05 21:08] jay |
common_tasks_in_applescript [2019/01/26 00:10] (current) |
Line 1: | Line 1: | ||
+ | ====== Completing Common Tasks in AppleScript ====== | ||
+ | This How-To will show you how to perform common tasks in AppleScript. These lines will run as is if they are run from an [[applescript|embedded AppleScript]]. If you want to run them from outside Indigo (i.e. Script Editor), then enclose them in a tell application block like this: | ||
+ | <code> | ||
+ | tell application "IndigoServer" | ||
+ | turn on "Office Lamp" | ||
+ | end tell</code> | ||
+ | * Turn on/off a light named "Office Lamp" | ||
+ | <code> | ||
+ | turn on "Office Lamp" for 60 -- leaves the light on for one minute (60 seconds) then turns it back off | ||
+ | turn on "Office Lamp" in 60 -- turns the light on after delaying one minute (60 seconds) | ||
+ | turn on "Office Lamp" in 60 for 60 -- combines the above two | ||
+ | -- the previous options work as well with "turn off" and "toggle" | ||
+ | </code> | ||
+ | * Brighten/dim a light named "Office Lamp" | ||
+ | <code> | ||
+ | -- Note: all brighten/dim numbers are 0-100 (0 being off and 100 being all the way on) | ||
+ | brighten "Office Lamp" to 85 -- sets the brightness to 85 regardless of previous setting | ||
+ | brighten "Office Lamp" by 25 -- brightens the lamp by 25 from it's current setting | ||
+ | brighten "Office Lamp" by 25 in 5 -- delays the brighten command by 5 seconds | ||
+ | dim "Office Lamp" to 25 -- sets the brightness to 25 regardless of previous setting | ||
+ | dim "Office Lamp" by 25 -- dims the lamp by 25 from it's current setting | ||
+ | dim "Office Lamp" by 25 in 5 -- delays the dim command by 5 seconds | ||
+ | </code> | ||
+ | * disable/enable time/date or trigger action | ||
+ | <code> | ||
+ | -- Each of the below enable statements has a corresponding disable command | ||
+ | enable time date action "Test T/D Action" -- enables a time/date action named "Test T/D Action" | ||
+ | enable time date action "Test T/D Action" for 60*60 -- same as above, but leaves the t/d action enabled only for 1 hour (60 seconds * 60 minutes) | ||
+ | enable time date action "Test T/D Action" in 60 -- enables a time/date action named "Test T/D Action" but delays one minute (60 seconds) first | ||
+ | enable time date action "Test T/D Action" in 60 for 60*60 -- combines the above two | ||
+ | enable trigger action "Test Trigger Action" -- enables a trigger action named "Test Trigger Action" | ||
+ | enable trigger action "Test Trigger Action" for 60*60 -- same as above, but leaves the t/d action enabled only for 1 hour (60 seconds * 60 minutes) | ||
+ | enable trigger action "Test Trigger Action" in 60 -- enables a trigger action named "Test Trigger Action" but delays one minute (60 seconds) first | ||
+ | enable trigger action "Test Trigger Action" in 60 for 60*60 -- combines the above two | ||
+ | </code> | ||
+ | * Execute an Action Group named "Test Action Group" | ||
+ | <code> | ||
+ | execute group "Test Action Group" -- execute the group | ||
+ | execute group "Test Action Group" in 60 -- delay the group execution by one minute (60 seconds) | ||
+ | </code> | ||
+ | * Execute an AppleScript in a separate thread ([[applescript|why?]]) | ||
+ | <code> | ||
+ | execute script file "MyDisk:Path:to:the:script:file.scpt" | ||
+ | execute script POSIX file "/Path/to/the/script/file.scpt" | ||
+ | </code> | ||
+ | * Getting information from a thermostat named "First Floor" | ||
+ | <code> | ||
+ | -- Getting the temperature and humidity from a thermostat is a little complex | ||
+ | -- because the values of those properties are actually lists - it's possible to get | ||
+ | -- multiple temperatures and humidity readings with the right equipment (with external | ||
+ | -- sensors, etc.) | ||
+ | set tempList to temperatures of device "First Floor" | ||
+ | -- tempList is now an AppleScript list - for a standard thermostat it will be something like {74} | ||
+ | -- with just one item. To get each item, you need to refer to it by number: | ||
+ | set theTemp to item 1 of tempList | ||
+ | -- After this line executes, theTemp will be equal to 74. | ||
+ | -- Humidity values work exactly the same way. If you're using an IO device that has multiple inputs and outputs, | ||
+ | -- they will also be presented as lists. | ||
+ | </code> | ||
+ | * Adjust a Thermostat named "First Floor" (these are just a few examples, look at the [[http://static.indigodomo.com/www/html/02300_indigo_as_dict.html#class_device__Indigo_Main_Suite|device]] dictionary for details) | ||
+ | <code> | ||
+ | set hvac mode of device "First Floor" to heatCoolOn -- operation based on the heat and cool setpoints | ||
+ | set hvac mode of device "First Floor" to runProgramAuto -- automatic operation of the Auto program that you create on the thermostat | ||
+ | set heat setpoint of device "First Floor" to 72 -- used when heatOn or heatCoolOn are set as hvac mode | ||
+ | set cool setpoint of device "First Floor" to 78 -- used when coolOn or heatCoolOn are set as hvac mode | ||
+ | set fan mode of device "First Floor" to fanAlwaysOn -- keeps the fan running all the time - fanAutoOn is the other option | ||
+ | </code> | ||
+ | * Control a sprinkler named "Sprinkler" | ||
+ | <code> | ||
+ | set sprinkler zone of device "Sprinkler" to 0 -- turns the sprinkler off | ||
+ | set sprinkler zone of device "Sprinkler" to 1 -- turns on zone one which will run for the max duration | ||
+ | </code> | ||
+ | * Creating/Getting/Setting Variables | ||
+ | <code> | ||
+ | -- Create a variable named "Test_Variable" | ||
+ | make new variable with properties {name:"Test_Variable", value:"Some Value Here"} | ||
+ | -- Get the value of a variable named "Test_Variable" into an AppleScript variable named theVarValue | ||
+ | set theVarValue to value of variable "Test_Variable" | ||
+ | -- Set the value of a variable named "Test_Variable" to "Hello World!" | ||
+ | set value of variable "Test_Variable" to "Hello World!" | ||
+ | </code> | ||
+ | * Log something into the Indigo Event Log | ||
+ | <code> | ||
+ | -- The following line | ||
+ | log "This is a typical log entry" | ||
+ | -- results in " Script This is a typical log entry" being inserted into the log | ||
+ | -- to change "Script" to something more useful, use the following line | ||
+ | log "This is a typical log entry" using type "MyTestScript | ||
+ | -- results in " MyTestScript This is a typical log entry" being inserted into the log | ||
+ | </code> | ||
+ | * Remove Delayed Actions - you know, when you set "Delay by" in an action, or use "in" when turning on/off a device. When you do that, Indigo creates a time/date action with a funky name and you may not know which action or device is associated with it. Here's how you do it in AppleScript: | ||
+ | <code> | ||
+ | -- This one will remove any delayed actions associated with the device named "Office Lamp" | ||
+ | remove delayed actions for device "Office Lamp" | ||
+ | -- This will remove any delayed actions from a trigger named "My Test Trigger" | ||
+ | -- (this can be either a time/date action or a trigger action) | ||
+ | remove delayed actions for trigger "My Test Trigger" | ||
+ | -- This will remove all delayed actions | ||
+ | remove delayed actions | ||
+ | </code> | ||
+ | * Supress logging - when you run scripts that operate devices, all of those changes get inserted into the log. In any given script, you may not want any of the results logged - or perhaps you only want one log entry for the entire script. Here's how you would do that. | ||
+ | <code> | ||
+ | -- NOTE: for this to work correctly, you MUST have the with transaction block INSIDE a | ||
+ | -- tell application "IndigoServer" even if this is being run embedded. | ||
+ | tell app "IndigoServer" | ||
+ | with transaction | ||
+ | transaction suppress logging -- Anything after this line before the end transaction line will NOT be logged | ||
+ | turn on "Office Sconces" | ||
+ | turn off "Office LampLinc" | ||
+ | set brightness of device "Office Overhead" to 35 | ||
+ | end transaction | ||
+ | log "Office scene created" using type "Office Script" | ||
+ | end tell | ||
+ | </code> | ||
+ | * Supress state change sending - some users have found that creating a "virtual" device - a device that doesn't actually have a hardware target, is useful for representing state in Indigo. However, Indigo requires that when you define a device you specify an address of some type for the device (X10 for instance). So, you can control those devices through scripts without Indigo trying to actually send the command: | ||
+ | <code> | ||
+ | transaction suppress state change sending | ||
+ | -- every state change command after the above suppress verb | ||
+ | -- that is inside this "with transaction" block will not send out any | ||
+ | -- interface commands | ||
+ | set brightness of device "Virtual Volume Controller" to 15 | ||
+ | turn on "Virtual Attic Fan" | ||
+ | end tell | ||
+ | </code> | ||
+ | * Use multiple conditions in a single trigger (specify no conditionals in the conditions tab and use the following as an Execute AppleScript action) | ||
+ | <code> | ||
+ | if ((value of variable "houseMode" = "night") and (value of variable "houseStatus" = "vacation")) then | ||
+ | -- do whatever you need to do here | ||
+ | end if | ||
+ | </code> | ||
