Indigo 2021.1 Documentation
Welcome to the Indigo 2021.1 Documentation pages. We've separated the docs into three areas, each focusing on some different part of Indigo 2021.1.
Indigo User Documents
Other Help Pages
Indigo Plugin Documents
- Email+ - allows users to integrate with email services. Used to be a 3rd party plugin but now is built-in.
- iTunes - makes iTunes information available for use in Indigo and allows you to control iTunes.
- NOAA Weather - makes weather data from the National Oceanic and Atmospheric Administration available for use in Indigo.
Indigo How-To Wiki
Technical Documents
- Working with Python packages - Details about working with Python packages that are not included with Indigo.
- Indigo Python Installation - Details about Indigo's installation of Python on the server machine.
- Indigo 2021 Scripting Tutorial - dive into scripting Indigo by examples.
- Indigo 2021 Server Plugin Tutorial - examples of extending Indigo via plugins.
- Indigo 2021 Plugin Developer's Guide - how to create plugin bundles for easy distribution, plugin UI, APIs, callback hooks, and more.
- Indigo 2021 Object Model Reference - the Indigo Object Model (IOM) and how to use it in Python.
