Glossary of Terms
Term Definition
Controller In Indigo, it's a device that controls another device. A controller may also be a responder (i.e. KeypadLinc). We've adopted the term from various INSTEON documentation.
Developer A person who writes Indigo Web Server (IWS) plugins or Indigo Server (IS) plugins.
Device A device is any “thing” that Indigo can interact with - usually it's some kind of hardware (light switch, appliance module, motion sensor, etc), but devices can also be other non-hardware things (iTunes server, calendar, etc).
Indigo Object Model (IOM) The IOM is how the various objects in Indigo are modeled in Python objects for scripters and plugin developers.
Plugin Indigo supports two ways to extend its functionality: Indigo Web Server (IWS) plugins and Indigo Server (IS) plugins. IWS plugins allow a developer to extend the functionality on an Indigo Control Page. IS plugins can extend Indigo by adding additional devices types, trigger events, and actions.
Responder In Indigo terminology, it's a device that responds to commands. A responder may also be a controller (i.e. KeypadLinc). We've adopted the term from various INSTEON documentation.
Scripter Someone who uses Python scripts to implement automation logic in Indigo via embedded or file-based script actions and script conditions.
Trigger A trigger is generally some kind of “event” that occurs. Indigo can use that event to execute actions in response.
Variable A variable is a place where your home automation logic can store information that changes during the normal operation of your home and that can be used in other parts of your system: for instance, you can have a variable that represents whether your home is occupied or not - then you can have special automation logic that takes place when that variable changes.
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/glossary_of_terms.txt
