Deletion Dependencies
If you double-click on the dependency, the edit dialog for that object will open so you can change/remove it. If you want the dependent objects to be deleted, just click the Delete button.
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/deletion_dependencies.txt
