With the addition of Z-Wave (and various plugins that define dimmer and relay devices) it's become obvious that we needed to provide some way to create technology agnostic scenes. You can, of course, implement basic scenes through Action Groups, and for many cases that's good enough.
To create a scene, you just create a new device, select Scenes
from the Type
menu, select On/Off Scene
from the model menu, and you'll see the configuration dialog:
To use a scene device, just use the standard Control Light/Appliance
action to turn it ON/OFF, and create triggers on the scene's ON and OFF state. That's it!
