name | string | the name of the folder - no two folders in the same namespace (i.e. indigo.devices) can have the same name |
Commands (indigo.*.folder.*)
| Parameters |
Delete the specified folder.
| Parameters |
| direct parameter | Yes | integer | id or instance of the folder to delete |
| Parameters |
| direct parameter | Yes | integer | id or instance of the folder to duplicate |
Get ID
| Parameters |
| direct parameter | Yes | string | name of any folder for the specified object type. |
| Parameters |
| direct parameter | Yes | integer | id or instance of the folder |
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
