Managing Your Z-Wave® Network
Connecting Z-Wave Interfaces
Indigo needs to communicate with your Z-Wave network through a USB interface, so check out our supported interfaces list to see if the interface you want to use has been tested with Indigo.
- Choose the
Configure Z-Wavedialog.
Adding a Z-Wave Device
- Select
Using Encryption
- Select
- Select
Edit…button). - Click the
Syncbutton. - When the
- Select
- When the
Deleting a Z-Wave Device
- Select
- Click the
Replacing a Z-Wave Controller
- Select the
- Finally, select the
Z-Wave Menu Options
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Reset Z-Wave Interface
