http://localhost:port/examplePlugin/handler1 http://localhost:port/examplePlugin/handler2 http://localhost:port/examplePlugin/handler3
http://localhost:port/examplePlugin/handler1?param1=p1val¶m2=p2val
So, how do you implement an IWS Plugin? An IWS Plugin requires a very specific layout of files/folders in it’s directory. Namely, something that looks like this:
/Library/Application Support/Perceptive Automation/Indigo XYZW.V/Web Assets/plugins/
css
- store CSS files used in templates or static pages (see below for details on templates)images
- store image files in this directoryjs
- store javascript files in this directorystatic
- store any static HTML files that your plugin would like to serve. For instance, you might want an about HTML file that gets displayed when the user selects a help link.templates
- store template files here (see below for details on templates)
The init.py
file is unused, but it’s required - it can just be empty. The meat of the functionality is in the reqhandler.py
. The structure of this file goes something like this: imports, static hook methods, request handler class.
Imports are just the imports necessary for your plugin to work. These are standard Python import statements. Some common imports you’ll need are .
PlugInName()
- this method should return a string with a human readable name for your plugin. It will be used in the Event Log when the plugin loads and will (optionally) be shown on the IWS index (landing) page.PluginDescription()
- this method should return a string with a human readable description of what your plugin does. This will (optionally) be shown on the IWS index (landing) page. to the right of the name specified above.ShowOnControlPageList()
- this method should return true if you want your plugin listed on the IWS index page (using the name and description above). If you want your plugin to show up there, you’ll need to make sure you implement an index method in your handler class (described below) so that when the user clicks on the name of your plugin in the list the index page will load.IndigoConnected()
and IndigoDisconnected()
- these methods are called just when their name implies - when IWS connects and disconnects from the IndigoServer process. Use these methods if you need to initialize and/or deallocate resources of some type.The last, and most important part of the code, is your request handler class. The methods defined in this class are automatically called based on the URL requested. The class itself may be named anything, but must be a subclass of BaseRequestHandler:
The plugin request handler must subclass from BaseRequestHandler and must call the parent class init
method:
def __init__(self, logFunc): BaseRequestHandler.__init__(self, logFunc)
def index(self): thePage = self.getReportForDay() return thePage index.exposed = True # exposed = True must be set for handler func to be called
index.exposed = true
That’s the basic structure of the reqhandler.py
file for all IWS plugins. You can have as many handlers as you like and they can process parameters just like any forms processing software. For instance, let’s look at the definition of the getReportForDay()
method that the index handler calls:
It would also be processed via a POST with those values in the form. Now that you know how to construct request handlers, let’s talk about how the reqhandler.py
file can communicate with IndigoServer. : add the appropriate stuff here.
<table> <tr> <td colspan=2 align="center"><h1>Report for $inDate</h1></td> </tr> <tr><th align="left">Device Name</th><th>Minutes ON</th></tr> #set $i=1 #for $deviceKey in $totalKeys #if (($i % 2) != 0) <tr class="darkRowBg"> #else <tr class="lightRowBg"> #end if #set $i=$i+1 <td class="deviceName">$deviceKey</td> <td class="deviceStateOff">$totals[$deviceKey]</td> </tr> #end for </table>
First we start the table and put in a header row. Then the local variable, $i
, is declared and set to 1. Then we loop for every key in the $totalKeys
associative array. If $i
is an odd number, we make the background for the row dark, otherwise we make it light. We then put the key (which in this case is a device name) in column 1 of the row, and something else (in this case the # of minutes the device was on) in the second column.
Cheetah templates can contain javascript, CSS, etc. - basically everything a normal HTML page can. lines that start with #
are interpreted by the template engine, and words starting with $
are interpreted as variables.
tmpl = self._GetAndLockPluginTemplate('usageReporter/templates/usageReport.html') try: tmpl.totals = totals tmpl.totalKeys = totalKeys return tmpl.RenderTemplate() finally: tmpl.ReleaseLock();
These two lines set the cheetah template variables (tmpl.totals
and tmpl.totalKeys
) to some the local Python variables (totals
and totalKeys
). This is how you pass data to a template - you just assign the template variable a value from your Python code.
This line calls the Cheetah RenderTemplate()
method that actually processes your template file along with the variables you pass in and creates a fully rendered HTML template. That gets returned by your handler to the browser for display.
